53 minutes ago, CWRNH said:
"0.1 Bypass caps on buffer stage lower pins"  Could you or anyone else please explain this to me?  I have everything done to this point and just need to know where these bypass caps connect....
Frankly, I am surprised the circuit works at all.  You have not provided a path for biasing the input stage of the LT1115.  You need a resistor from the non-inverting input to ground.  Pick a value to place the pole where you want to get your flat-band response.
Edited by LittleWatchShop
nin-<non
Thank you!
Not my design, I am making a modified version of this.  What value should I start with for the Biasing of the input stage?  Sorry I am new to this...  Not totally incompetent but certainly don't have a through understanding at this point.  Any help is greatly appreciated.   Here is the PCB so far, based on the schematic.  Will modify it once I get a functioning board.image.png.43e5ec29563003cd129ee1a8beec1f21.png
Other than in the rail splitter, I do not see any bypass capacitors.  Poor practice.  You need to bypass every amplifier.
For your input resistor, a 10k should work.
Okay, I will put caps on pins 4 (V-) and ground on all amps and pins 7 (V+) and ground on all amps.   And will bias the main input with a 10k resistor between pin 2 (-) and ground of the first op amp.  Is this what you are talking about?   Again, thank you for your time.  I will post the updated board image when done.
13 minutes ago, JohnR725 said:
How do curiosity the modifications purpose is to achieve what?
I want to first get a decent working preamp setup.  Then refine it a bit and I want to add a UART output, among other things.  The preamp is only a small part of the project.  There are many different schematics and ideas, I have tried a few.  I am also trying to learn how all this stuff works, partly for curiosity sake and partly to build a machine that does some very specific things that I will explain later on as I am working them out.  I have several commercially made timing machines so this endeavor is more of a hobby at this point.   Electronics have always been an interest to me, I have finally gained some of the knowledge and equipment to pursue this hobby.  There are many projects that I have built and am planning on  building.  So....  I am, right now, trying to find a good quiet preamp.. LOL
2 minutes ago, svorkoetter said:
What I find interesting is to ask questions about the circuit with only a circuit board layout instead of an actual schematic.
I simply wanted to know where HE (the person who made the schematic, that I created the layout from) was putting the bypass caps.  I can share my schematic too if you wish.  If I am asking something that is foolish I am sorry.  You don't know what you didn't know until you learn that you didn't know it.  This isn't rocket science but I don't have as much experience with electronics as you fine folks.  Sorry for any misunderstanding.
Yup!
Just now, LittleWatchShop said:
@cwrnh ...what layout tool are you using?  Looks like ExpressPCB.
Lately yes, Express.  I also have used Eagle but I am liking Express better.  I use Fusion 360 for most of my regular CAD/CAM nearly every day so I thought I would like Eagle but it is not as simple to use.  I used TINA do make the schematic and do some simulations.  Thankfully the tech school I teach at has a decent electronics department where I get some help.
  • Similar Content
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
    • The two measurements of particular importance wound be the height and the strength,  the length would obviously correspond with the increase/reduction of half mm of barrel diameter. There is a big difference in price considering that the more expensive one is the shortest. The longer one might be ok ? But then it is taking up more room in the barrel, might it effect the unwinding ? I wouldn't have thought so for just that small amount.  Ideally a pro might reduce the longer one to suit. But there is some information that might help, do you have the one that was fitted to measure up, though not necessarily the right one.
