53 minutes ago, CWRNH said:
"0.1 Bypass caps on buffer stage lower pins"  Could you or anyone else please explain this to me?  I have everything done to this point and just need to know where these bypass caps connect....
Frankly, I am surprised the circuit works at all.  You have not provided a path for biasing the input stage of the LT1115.  You need a resistor from the non-inverting input to ground.  Pick a value to place the pole where you want to get your flat-band response.
Edited by LittleWatchShop
nin-<non
Thank you!
Not my design, I am making a modified version of this.  What value should I start with for the Biasing of the input stage?  Sorry I am new to this...  Not totally incompetent but certainly don't have a through understanding at this point.  Any help is greatly appreciated.   Here is the PCB so far, based on the schematic.  Will modify it once I get a functioning board.image.png.43e5ec29563003cd129ee1a8beec1f21.png
Other than in the rail splitter, I do not see any bypass capacitors.  Poor practice.  You need to bypass every amplifier.
For your input resistor, a 10k should work.
Okay, I will put caps on pins 4 (V-) and ground on all amps and pins 7 (V+) and ground on all amps.   And will bias the main input with a 10k resistor between pin 2 (-) and ground of the first op amp.  Is this what you are talking about?   Again, thank you for your time.  I will post the updated board image when done.
13 minutes ago, JohnR725 said:
How do curiosity the modifications purpose is to achieve what?
I want to first get a decent working preamp setup.  Then refine it a bit and I want to add a UART output, among other things.  The preamp is only a small part of the project.  There are many different schematics and ideas, I have tried a few.  I am also trying to learn how all this stuff works, partly for curiosity sake and partly to build a machine that does some very specific things that I will explain later on as I am working them out.  I have several commercially made timing machines so this endeavor is more of a hobby at this point.   Electronics have always been an interest to me, I have finally gained some of the knowledge and equipment to pursue this hobby.  There are many projects that I have built and am planning on  building.  So....  I am, right now, trying to find a good quiet preamp.. LOL
2 minutes ago, svorkoetter said:
What I find interesting is to ask questions about the circuit with only a circuit board layout instead of an actual schematic.
I simply wanted to know where HE (the person who made the schematic, that I created the layout from) was putting the bypass caps.  I can share my schematic too if you wish.  If I am asking something that is foolish I am sorry.  You don't know what you didn't know until you learn that you didn't know it.  This isn't rocket science but I don't have as much experience with electronics as you fine folks.  Sorry for any misunderstanding.
Yup!
Just now, LittleWatchShop said:
@cwrnh ...what layout tool are you using?  Looks like ExpressPCB.
Lately yes, Express.  I also have used Eagle but I am liking Express better.  I use Fusion 360 for most of my regular CAD/CAM nearly every day so I thought I would like Eagle but it is not as simple to use.  I used TINA do make the schematic and do some simulations.  Thankfully the tech school I teach at has a decent electronics department where I get some help.
  • Similar Content
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
    • Aloha and thanks for catching all these small but important details, John.  I'm going to give it a shot. The good news is I have a parts movement here with a perfect complete balance.  I will place them side by side for visual reference when doing what you outlined.  It's been a while were I've had a hobby in which I joined a forum.  I forgot just how helpful everyone can be. Mahalo. Frank.
