Stereo Microscope
8 hours ago, winchman said:
I looked at these on Ebay but would it work on a Mac? No mention in system requirements?
Dont know but yesterday i have found the perfect app to use this camera with. It is the NCH Debut software.
I have tried Media Player HC, VLC, Youcam, free2xcam and even WIndows Movie Maker ... all had some issues, random but great picture delay which made lathe work hard, no fullscreen...  Even a simple picture was sometimes a headache. But this Debut seem perfect so far.
Been after one of these for a while, but wanted to try before I bought. Had the chance at a motorsport show I was at for work this week. Have to say, I'm very impressed.
This is the unit
http://www.oasisscientific.com/2mp-usb-digital-microscope-12mm-with-new-stand.html
Which I got on a show special for $70.
And here are a couple of sample pics.
So far very happy, it has a great working range and also connects to my phone, making it practical to use to work under (fliping the phone upside down means everything moves the way you expect it too)
14 hours ago, vinn3 said:
good show ! so;  do you just plug this into your computer and take a photo?   F.M. (magic)
Yup, pretty much, I'm using a free bit of software called Plugable Digital Viewer which the manufacturer recomended. There are other options for the scope as well, they did one that cleverely combined multiple images to give more depth of field but it was a bit more cash.
It is the first time I have actually been able to see side play on pinions etc. Looking forward to spotting dirt after cleaning movements that under a loupe look clean!
Cheers mates, I have with great joy reading about this microscope, and this great photoes.
Thought I just should tell you about this type of microscope I have been using for some time. And it working great...
www.brunelmicroscopes.co.uk BM1 long arm microscope
I think there is a tread her someplace about it, but I can find right now. But this is the best investment I have done...
Working with reluming, setting the second arm, placing the balance wheel and so on....
Hey thanks, I will check this out.
  • 5 months later...
Hello. We are planning to use Bausch and Lomb SZ7. Can this microscope achieve a100x magnification with at least 10cm working distance  -we prefer longer working distances for our application? We have standard 10x eyepieces. What optics/lens should we get for this? We are not familiar with B&L optics, not sure what options are compatible with this microscope, and would be thankful for suggestions. Thanks in advance.
I have a Bausch and Lomb microscope over my lathe.I am not sure of the model as I purchased of of the Bay. It has very good clear optics & the normal working distance is approx 7cm.
To get >10cm working distance with the SZ7 you need to use a .5x lens with the 30x eyepieces. It's not possible with the standard 10x eyepieces.
Here's the relevant page from the manual, showing the various magnifications and working distances.
Edited by Rob
  • 7 months later...
Has anyone replaced their Isoma Centering microscope or similar optical device with an electronic gadget, like a snake inspection camera, a DSLR, or electronic microscope, some other Chinese made electronic wonder that gives an output to a PC monitor?
I am trying to fit out a Schaublin 102 size lathe for gear cutting and other work. I don't have an Isoma microscope, but lots of people certainly used to use these, and as they are up to £400 second hand it is not a cheap investment.
I picked up an Isoma microscope locally quite cheaply, from a guy that was renting a unit in the old ETA factory, but it turns out this was an optical measuring device that was used for tool setting, and it doesn't have a built in light facility. Basically it is a massively heavy steel plate, and the microscope is moved around with hand wheels like a cross slide.
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
