A Little Fun
oldhippy
I thought I might have had a few more comments on this one still never mind. Thanks to those for having a go.
The whole thing really is a bodge up.
No winding holes to wind up the movement.
The top handle is way too small and a different colour to the rest of the brass? fittings.
J Boot Sutton doesn't even belong to the dial, it's been added and is crooked.
Both hands are wrong they would be pierced and ornate not spade which look cheap and nasty and to be honest stick out like a sore thumb. There's no pin or nut to hold them on.
No door to open to set the hands. The whole front window comes off by a latch on each side of the case which is very odd. I think part of this case has been rebuilt it looks wrong.
The spandrels are odd.
I found this on ebay. The seller pointed out many faults so they aren't trying to deceive potential buyers. I can't think why anyone one would want to buy it. The movement in this thing is French with a platform cylinder escapement with hand setting from the back and more than likely is of 8days duration. The seller says its Georgian? To me it's just not good enough to be Georgian.
The original movement would be an English Fusee timepiece or strike with pendulum. That's if this case was built in the Georgian period, which I don't think so.
To those that got things right give yourselves a pat on the back and thanks for taking part.
  • 4 months later...
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
