  • 0
Gingerr6
Basic Cleaning.
Question
Afternoon Guys,
I have just purchased and Tissot with a 2824-2 that needs a refresh.
I have repaired 2 of the same movement before but this will be my 1st full strip and re build.
What's the best way of cleaning the parts either by hand or ultrasonic?
do I need specialist chemicals? bear in mind I wont be doing this all the time :)
list of parts would be appreciated.
Many thanks
James.
post-1206-0-56116000-1439987291_thumb.jp
Share this post
Link to post
9 answers to this question
  • 0
I think the movement is an ETA 2836-2. If so the strip down and drawings can be found on the ETA web site. It looks like the movement has had water ingress so a complete strip down,clean reassembly & lubrication will be required.
Agree with CB that acctually looks like a ETA 2836-2 movement . Tissot only has 21 jewels and has a different rotor .
Edited by rogart63
Share this post
Link to post
  • 0
Hi Ginger, the 2.5x magnification should be fine for stripping and assembly, although being old and blind I tend to use a 3.5x. The 8" means you will have roughly 8" of space to work between the visor and movement.
If you are just starting off, I would recommend using Ronsol or Zippo lighter fuel and a small brush to clean the parts. An ultrasonic tank would be a lot better, but I would hold back on that and proprietary cleaners until you find out how keen you are going to be.
Share this post
Link to post
  • 0
Excellent. I guessed as much on the 8".
Good tip about the lighter fluid :) thanks.
Sent from my HTC One using Tapatalk
Share this post
Link to post
  • 0
Hi ginger, I recently cleaned a movement that had similar signs of water ingress & I found this video Mark did very useful. Although it's of a 7750 movement,  he does show &  discuss a couple of methods he used to clean the particularly bad areas. I think it's round 14mins in https://youtu.be/BesSK67Mzms.
Share this post
Link to post
Answer this question...
Loading...
  • Similar Content
    • By jakobvinkas
      Hello, I could not fint any answer to this on any other thread.
      Im using Isopropyl alcohol for the last step of hand cleaning movements. However i can not find a good way to throw used liquid away. How do you do it, I know that the liquid will turn into gas eventually however since i fill a small jar there is always going to come times when i need to throw it away. Where do i throw it?
      How do you do it?
      Thanks in advance, Jakob
    • By dreja
      Hello,
      I have disassembled the Poljot 2209 movement.
      I would would need your advice, if it is ok to wash also the "double gear" and how to oil it later...
      Thanks
      Andrej
    • By bertmengels
      Hi to you all,
      I was wondering, if you use a regular ultrasonic instead of a watch cleaning machine. How would you rinse your parts? And how many times? In which solutions?
      I always cleaned my parts in the ultra sonic with a solution and rinsed the parts in benzine( that's the way an old watchmaker learned me) but i've found out that very often this does not give me the results i was hoping for. Can I perhaps get little jars with a rinse solution and run those in the ultra sonic?
      thanks!
    • By Hayley
      Hi,
      I have managed to get hold of a singing bird cage at a reasonable price after years of trying.
      It's not working...I would like some advice on what solutions to use to clean it as I think it just requires a good clean, nothings broken.
      Can anyone tell me what make of cleaner to use and what lubricant would be best, have attached photo's!
      Thanks
    • By Paul78
      I've just changed my cleaning fluid in my Elma cleaner to the Elma WF Pro, I've done one movement, the fluid was clear but now it's gone blue. Does anyone know of this is normal? Or should I change it?
    • Hi Dan, Welcome to the forum.
    • A soak in diesel fuel, naphta for day or two,  ends the old story of heads popping off the screws. I remove balance cock pallets and soak the rest, give one dip in a fluid I can stand the odor of. Any cheap multipurpose oil would do. I use several solutions, detergent seperately and brush extesively.
    • Hello forum folks, I've been tinkering with watches for maybe 5 years now. I'm very much a beginner but I have been practicing on cheap watches and movements that it is ok to break. I've managed to make my own watch dial from a brass sheet, including brushing, rhodium plating, printing, and creating applied markers and numerals. I've also made a "smart" watch using epoxy-based putty for the case and my electronics knowledge. I have some basic skills in metal finishing including polishing and plating. So I've mostly worked on the non-movement aspects of watchmaking and am interested into learning about servicing movements. I live in the Milwaukee area and was thrilled to see MATC (local trade school) on lists of schools that teach watchmaking -- just to have that dashed when I contacted them and the class has been discontinued for lack of interest  So for now, I have online and book resources to learn. I have a mostly cheap watch collection other than a Longines that I treasure. I have a few different old timex mechanicals I got off of ebay, including 2 from JerseyMo which I saw is on this forum. I have have way more hobbies than time so I'll probably be around off and on. Dan
    • First thing would be to remove the pinions. They are sometimes quite well rivetted, so this may involve turning away some of the rivet or being willing to sacrifice the wheel (it could easily be distorted beyond use in punching the pinion out). Then you need to compare the hole in the wheel you want to use to the diameter on the pinion that will be pressed and rivetted in. If too big it gets tricky, you'll need to sleeve/bush the hole very securely. I would open the hole further, then chamfer both sides, make the bush with an undersized hole, then fit it in. Swage the bush with a convex punch in the hole from both sides, then a flat punch that is larger than the bush. The idea is to deform metal into the two chamfers on the wheel. Finally flatten and clean up. Now open the hole to receive the pinion. If the hole is too small it's easy, just open it up and press/rivett the pinion in.
    • Thanks @jdm its easier if you know the correct name / term, that helps a lot.
