New Toy
chadders1966
Hi,
I don't know about everyone else, but I often find myself spending more time and money on purchasing tools than watches :). This is my latest purchase arrived today - can't really call it vintage, but I have only found it for sale at Ofrei for large amounts of money (http://www.ofrei.com/page236.html).
I got it from the same seller on German EBay as I've bought a lot of tools. The prices seem more reasonable and they often have items (like this) that don't torn up elsewhere. As you can see the entire back row of dies is missing. Looking at the current Sternkreuz catalogue those are all the dies for fancy shapes. Anybody got any spare ;)? Everything else is there apart from whatever is supposed to go on the left. It is marked Glasabzieher No 881 - I can't find any information on what that is. I'm also not sure about the two brass pieces at the front right, and the two circular pieces I put in front which have no place. I think the plastic pieces are from something else.
I particularly like the set of adapter spindles that come with it - this is a photo of the extra one they sent. This means that not only will it take any Sternkreuz plastic/Bakelite die of which I already have a set, but with take any standard screw dies.
At first I couldn't figure out why the press was lifted proud of the board. After a bit of fiddling, and noticing the screw hole on the back of the press, I realised it was so the press can be mounted horizontally as well as vertically. What I can't figure out is the purpose of this. Anybody any clues?
Stephen
Thanks guys, I'm very pleased with it, looking forward to cleaning it tomorrow. Looking again at the Sternkreuz catalogue those two spare round plastic pieces are from a different set and are dies for mineral glasses. Also the two brass pieces at front right definitely don't belong, there are supposed to be two convex rubber chucks there. The brass pieces don't seem to fit at all and have no markings. I'm most intrigued though by the possible horizontal positioning though - why?
On German EBay at the moment there is another set, don't know if I can put a link to a live auction, but I found it by searching Sternkreuz. This set has all the fancy dies missing as well, but it has the tool that should be on the left hand side with it. Even though I can now see what is meant to be there, I have no idea what it is for. Google translate just comes up with glasswiper, which doesn't really help. Any suggestions?
Stephen
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
    • Thanks guys.  quick question. For automatic movement, particularly this one. can I power down the main spring by pushing this rachet down?  i've gotten pretty used to SW210 and powering down a manual movement. But so far i've only been waiting for the auto movement to run out of juice before opening the case.
