Hello everyone from Ukraine!!!
petro
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
We all know what is going on in the Ukraine and I wish you and your people a peaceful and happy life. God bless you all.
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
