Trevel clock Looping
Good day everyone! I am new to your forum. I got a strange Looping travel watch. It is made in Switzerland. But I have not met this type of mechanism anywhere. So I'm posting a photo, maybe someone knows this type of mechanism. Best regards, Peter
0-02-05-5b32269cee6fc21f8eed304f307770fb4200b5c8f90fc7048d3c02123543967d_6221163d7c9e5234.jpg
0-02-05-9d2dd128641212d39bce916b3120055013c0c0a9effe8bc8938bdec44a85b200_791b8de54f8d93c6.jpg
0-02-05-47a5910745f136cc3f8b4b6d9634c93bd8f90c84a46d9e6e93a594a61ee7d9c5_68294d4f2aabb0ec.jpg
On 5/22/2023 at 5:21 PM, petro said:
Thank you for welcoming me to your community! I need to know about that mechanism. I sent the photo. Maybe someone knows about such watches?
Best regards, Peter
It has one winder that winds the going and the alarm side, the alarm runs if you do not stop it or shall I say you fail to wake up it will run down and stop by means of a stop work. They are good movements and the parts should be cleaned in a watch cleaning machine. It is an easy movement to take apart and put back. I would suggest you take loads of photos as you take it apart. Oils to use a good pocket watch oil on the going and alarm, windles clock oil for the barrel spring and arbor and on the alarm wheel next to the hammer and where the hammer contacts the hammer wheel. Just ask if you need anymore advice.
Edited by oldhippy
Good evening! Thank you for your attention and understanding! Do you sometimes have a scheme for assembling the mechanism of this type of watch? It appears to be Looping caliber 44/45. Or a link to a site where you could download such a scheme. I would be very grateful!
Regards,
Peter
Thanks, Oldhippy!!!
Best regards,
Peter
I will be following this thread.  I have a Looping travel alarm clock also, and I will post pictures of mine in a bit.  But I did not find any technical documents or diagrams about it either.
Addendum: adding pictures of my own movement.  It is in fantastic condition and amazingly accurate.  It is apparently very rugged also, because its case was a wreck.  I plan to make a beautiful case for it later.
Edited by KarlvonKoln
Addition
    • Ok thanks Ross, I will give that a try!😁
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
