ESTIMA Travel /alarm clock
berniethebolt
hi. a friend of mine give me an estima travel clock to look at for a neighbour of his;(a widow) it has sentimental  value although it is not worth much! when i opened it i found that the clock ticked away merrily (as it is now at my side) as long as it was face down. any other position it stopped. i know the balance assembly is different here with the balance wheel at the bottom of a pivot and the hairspring at the top! when i looked the wheel was engaging the escape wheel ok and the hairspring looked flat without any kinks. any ideas?
I would love to see pictures of it.  As to ideas, I would start with cleaning it first.  Once you know it isn't being bogged down by old dirt, then you can more effectively search for problems.  If it still stops after cleaning, I would look first at the balance pivots and bearings/bushings.  And then work up the train from there.
    • Hi Vandan. Hi from a fellow newbie! Marshall has got a lot to answer for hasn't he! 😄. I also got hooked to this hobby after watching his videos.  Good luck with your journey to service your Grandfather's watch.   Nick
    • Hi all, I have a lovely Favre-Lueba dress watch from late 70s/early 80s in a stainless steel case.  Its an unusual curved rectangular case and crystal.  I'm wondering if there's any possibility I might be able to buy/find a replacement crystal for this watch.  The base of the crystal is also curved to match the case, rather than flat.  I'm looking at the Cousins website page here https://www.cousinsuk.com/product/rectsq-rounded-corners-one-side-curved-bezel-sternkreuz-rzr but not sure if I'm looking for the correct type.  In my case its a rectanglular crystal with rounded corners, and both the upper and lower surfaces of the crystal are curved.   Update - OK I now think I know what I'm looking for, but Cousins don't stock the size I need :-).  I think I need a Sternkruez RZ 315x220R9, acrylic, cylindrically domed with rounded corners.  Any tips or alternate sources for this source of crystal. Many thanks
    • Getting more interesting this post, innit? Mikeplilk, Waggy. Impressed with your efforts. Makes mine look amateurish. Hey, that's what I am. Still, I have good results with the 'frog'. Apprentice test piece. Paper is from https://www.ebay.co.uk/itm/234602659940?var=534248554534   I am aware that the more I delve into the DIY, the more I am gaining understanding of watchmaking. Well, a little each time. Ross
    • Now, that's a bad boy watch! 🫡
    • High frequency day: 36000 bph.
