Elma Watch Cleaning Machine
I know Mark has one of these machines, I recently purchased one myself, and its in dire need of restoring.  I have stripped it down, and wish to rewire it and replace the ageing motor speed switch with a modern alternative, so could really do with a wiring diagram if anyone has one?
Hi Micky,
Have you found anywhere that would sell a new rheostat for the elma? Mine has little to no adjustment on the motor speed anymore. I have managed to set it at a manageable speed but it would be nice to ramp it up during the spin-off.
Yes Mark, found a small alternative to the variable motor speed switch...
http://www.ebay.co.uk/itm/New-AC-50-220V-2000W-Motor-Speed-Control-SCR-Controller-Knob-Switch-/251665634527?&_trksid=p2056016.l4276
Also found complete new machines, one without timer, and another twitch timer for £299 and £399 each, but wheres the fun in that?
Prefer to restore my own.
For anyone interested in the new pieces, see below..
http://www.ebay.co.uk/itm/Watch-cleaning-machine-janta-pearl-brand-cleans-rolex-omega-tissot-2045-/111473300849?pt=UK_Jewellery_Watches_WatchAccessories_SpareParts_SM&hash=item19f4539571
With timer..
http://www.ebay.co.uk/itm/Watch-cleaning-machine-janta-pearl-brand-with-timer-cleans-all-watches-2047-/291253631038?pt=UK_Jewellery_Watches_WatchAccessories_SpareParts_SM&hash=item43d011b83e
Janter Branded.
Edited by SSTEEL
I also have one of these elma cleaners, it seems that there is now a buzzing sounds and the switch doesnt really work, after long use there is a slight smell of burning. Im assuming i need to clean up the bearings in the motor and replace the switch.
I could probably figure out the switch,but wouldn't know how to clean up the motor bearings.
Any help would be appreciated.
Thanks
J
I wouldn't be over concerned about the bearings unless they are making a noise. The switch on the other hand will probably be what is making the buzzing sound. If you can't get the switch apart to clean the contacts, I recommend you get a new one sooner than later. In all honesty, you should replace the switch anyway.
Once you have replaced/repaired the switch, run the machine dry and hold the blade of a long screwdriver to the top and then bottom of the motor as close to the bearings as possible, and put your ear against the handle. You will be able to hear how good the bearings are. There should just be a gentle hiss, if they are screaming or rumbling, replace them.
Well my Elma Super Elite is coming together slowly, I have removed all the old paint from the circular base, heater chamber, and motor cover so far with the timer housing and front fascia, and central pole clamp currently soaking in acetone ready for the refinishing.
Base..
15648207765_907ecf80c9.jpgUntitled by Micky.!, on Flickr
Heater chamber, and motor shroud..
15678012071_882950fef3.jpgELMA SUPER ELITE REFURB by Micky.!, on Flickr
I have purchased what I think is the correct hammered blue paint, but I am actually now considering not painting it a colour at all, I might just clear coat it to give it that rustic look, undecided at the moment, so any opinions would be greatly appreciated.
Edited by SSTEEL
That's one hell of a thorough job your doing Micky, I'm looking forward to seeing the end result. Regarding finish, I think I would go with the blue hammered finish, I think it might be more durable and resistant to cleaning fluids.
Thats very useful info - thanks for sharing.
I am sure Graham Baxter uses powder coating when he referbs the L&R machines - is that an option for you?
I have never done powder coating so I don't know what is involved but I understand it is very durable.
Ideally Mark, I would love to have it powder coated, but alas I know of nowhere local that offers this, so what I done is found a very close match blue, with hammered effect, its brush on Hammerite.  I just hope I manage to achieve a nice even coating with it.
Edited by SSTEEL
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
