Croton with an ETA 2472
Razz
My latest aquisition. Dial is pretty subtle but decent. Hands were off. Non running. Description on the lot did not have info on the movement.  20 to 30 minutes to remove the dial and put back on with reattached hands. Messed around with the automatic winding and fiddled with it until a very low beat on the balance for about 20 to 30 seconds. So another project to step up a level to an automatic with calendar. Will need to get the lube for the automatic gears though first.1702834031_DSCN51672.thumb.JPG.585c9bc04bedca3688ef035ba6e8196f.JPG500568425_DSCN51682.thumb.JPG.4ef3baa6ae790a9f921a1231f01bfbf5.JPG1150977894_DSCN51692.thumb.JPG.167c4a49bc0ea9faf7348ad2ccef5ae0.JPG1305144513_DSCN51702.thumb.JPG.b914e4222bbf3b6345102876ec517bd8.JPG2114352391_DSCN51712.thumb.JPG.d484c046628794865be6a16f3cbcbf03.JPG
Great movement, I have one on my wrist at the moment 😄 make sure to check out this walkthrough if you haven't already:
By the way, mine was also a non-runner when I got it. Turned out to be too little end-shake on the balance. The lower (mainplate) endstone assembly for the balance was quite easy to shim. Not sure if this is a common "fault" with these movements, but I'd suggest you check the endshake on the balance first. Try loosening the balance cock screw a little and see if it kicks into life.
Do you mean that you made the cap jewel thinner? Maybe not. Anyway, I'd really like to hear more about it!
Oh no, that would be way outside my comfort zone! I simply unscrewed the disk that holds the cap jewel assembly and shimmed it with a couple pieces of thin foil. Shimming the balance cock would probably have worked as well, but I believe it would have been more difficult due to its geometry. Side-note: Do you know why the lower assembly is held in place by a disk such as this?
The leading theory is that the balance was replaced at some point, and that the new balance staff was slightly longer than the original one, but it's hard to be sure. Anyway the movement runs with ridiculous amplitude now - well in excess of 330 degrees DU/DD, and it does knock a bit at full wind when I move my arm too much. Maybe someone replaced its spring with a slightly stronger one to combat the binding balance? I should inspect the mainspring again... one day! There are too many projects on my bench.
That's very interesting, thanks, and reminds me very much of the Russian approach (Vostok, Raketa, Poljot, etc.) where you'll most often find one or two shims under the balance cock. I would have thought thin foil (I assume you mean aluminium foil!?) to be too tick, but perhaps it's an ideal material. Got so curious I'll measure a bit of aluminium foil right now. Back in a minute...
This is the aluminium foil I found in my kitchen drawer and it's 1/100 mm. So, pretty ideal I'd say. One or two shims would in most cases, I believe, be enough to make the necessary adjustment.
I'm afraid I have no idea.
Or, perhaps, oil the pallet fork jewels with a bit of thick oil (HP-1300)?!
I've heard that as well, though I still haven't worked on anything Russian yet.
Jealous of your micrometer there... And yes, I used two tiny strips of basic aluminium foil for this.
I did play around with adding some D5 to the pivots which seems to reduce amplitude by around 30 degrees after a short test. This might be a viable solution, but I'll have to let it run for a week or so to be sure.
  • 4 weeks later...
I tried to loosen the balance cock screw a bit without much success. So decided to clean and oil the balance jewels to see if that would help. I opened the balance cock incabloc spring easy enough and got the end stone  jewel and chaton out okay and put in an acetone rinse. I then tried to get the end stone off the chaton and it was stuck! I tried soaking over night and still would not come apart. I finally used a new balance pivot to push the end stone off to clean and oil and put back together. Had to repeat the process for the end stone and chaton on the plate under the dial. I think with these 2 now a little more flexible under the spring and not jammed into the chaton this gave a little endshake and runs great now.
With an all SS case with drilled lugs, original dial and hands this looks pretty good, without doing much more than an ultrasonic cleaning of the case.
I wonder what the CHP is about. I was thinking maybe California Highway Patrol...lol. maybe ponch (Erik Estrada) wore it during filming of the TV show. Anyways another look at it.906907024_20230510_1948152.thumb.jpg.31a5f6cc43e188e665b1ad600cce1e7d.jpg233118540_20230510_1948272.thumb.jpg.1603fd7c89fc5ced256a3372cfda92a4.jpg1481918069_20230510_1955562.thumb.jpg.6ef2a2dde96d559df78b6352bfcdcf4c.jpg
    • Haha. You're just in a wicked mood today John 😅
    • Heres my watch of today, a Smith 13'" RY . My missus bought me this for this Valentines day a bargain 14.99 with a reduction, the seller has occasional 20% off offers now and then so it was about 15ish with delivery. I love Smiths and i love bulleye dials, this is my first one. The watch arrived non working as stated and i knew what was inside and what would be against me, but i enjoy a challenge, we dont expect a lot if anything from pin pallet movements. A balance pivot was broken and i didnt have another staff but i did have another RY with a battered dial so i robbed the balance and tweaked it around to make it work apart from that mostly just a good clean and relubrication. Keyless works are pretty rough by design and the crown is a bugger to get in and out with the dial on, the setting lever hits the dial before it releases it, so a little mod is needed to help that along. Major problem was the pins on the lever were quite worn which make the old tg have a snow storm fit. Its a similar read for most pin pallets, these were brass as was the escape wheel. But perseverance is me, i didn't change the pins but i did spend some time dressing and polishing the worn areas which improved the trace a lot with some straightish lines 😅 and a beat error of .5 . Not sure what the lift angle should be on these and i Wasn't in the mood to work it out and who believes timegraphers anyway, but at the default 52° it runs with 260ish full 210 after 24 hours dial down , the verticals rates were pretty much all over place. So lets just put it in it's superlight aluminium case and see what happens. Been wearing it now for 3 weeks and it's consistently losing around 1.5  minutes a week winding each morning i think pretty good for an old pin pallet watch. I just love this dial, thanks wifey heres my Valentine's gift for yer sweetie x
    • I have a PDF below that will help. The problem was the PDF wasn't designed for this purpose it was designed to tell you what size watch you  have. Then it doesn't take into account movements come conceivably in different thicknesses.   watch-ligne-size-chart.pdf
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
