Servicing My First Chronograph!
"Try using a vacuum cleaner with ladies tights stretched over the end of the hose!"
This is a fantastic idea!
I don't know about this. I tried it but my wife was annoyed and got a cramp while I pulled the tights away from her leg and used the vacuum. :)
This has been a great post .
Thanks to everyone for their input and contributions . Unfortunately I have experienced all of the pitfalls that GuiBer encountered . I re-lived the Incabloc dilemma and can relate to the replacement of the spring . I too thought that It would simply twist into place , but also came to the conclusion that I would need a press or other tool to do the job .
  While I also have put a screwdriver into the balance and hairspring the first time I attempted to service a movement , {rookie mistake caused by purpose tremor]
my best trick is to have the balance assembly flip out of my tweezers because I am anxious to to install it and see the watch in motion . That mistake results in a hairspring birds nest every time .........I've done it 2 or 3 times.... :startle:
Congratulations on a fine job GuiBer....
I had to replace a similar incabloc spring on the balance cock.  I too tried for many hours to insert the spring from the jewel side but was unsuccessful every time.
The way I did it was to remove the balance cock from the hairspring.  Ease up and detach the regulator and stud rings.  Place the incabloc spring flat pointing away from the jewels and slide it into the block slot.  Then hinge it over onto the jewel loosely.  Replace the regulator and stud rings (they push on) and the incabloc spring should be secure in the block.  With the jewels in place fit the incabloc spring to the jewels to check all is well.  Refit the hairspring to the cock.
  • 3 months later...
    • I dont like to give up things that i enjoy Tom.  So my next question is how are we going to prepare for that inevitability and what are we going to do about it. Its not just about funding it but I did pick up on something that Mark said once. It doesnt run on fresh air , what if it becomes a burden or an unnecessary cost or for any other reason that i wont get into. We all know life can change in an instant, my life has been so up and down for about 8 years and was only just beginning to level itself out.
    • What I especially like is that this forum is not full of ads. There are some but they're not interfering. No ads between posts like one certain big watch forum. Browsing is also very easy and light for a mobile device. I'm glad there's still room for old school forums like this. I'm a member in many facebook groups but there's really no long term discussion and if you see an interesting post you might never find it again if needed.
    • Hey, Nick! Thanks for sharing your beginning attempts in watch repair and welcome to WRT. I am familiar with the Citizen and the Sekonda. Likely the Citizen houses a Citizen cal. 8200A and the Sekonda a Poljot 2614.2H. I have serviced several of both and made a service walkthrough of the Citizen which you find if you click here. There's a lovely story about the Poljot movement on TimeZone.com called Jessica’s Cornavin Dolphin. Good luck!
    • A perfect example Hector, with the forum we would lose so much more My sentiments exactly Richard, i have experienced  that loss already,  Tiny, Gert, Galilea to name but a few all of which i enjoyed conversations with. I imagine it keeps a lot us sane OH.
