Beginners clocks
57 minutes ago, watchweasol said:
Hi Richard.  The center can is best left alone unless the pivot hole is worn then it needs removing using large levers as does the kidney cam(gathering pallet) to be correct.   A pair of levers or a puller, I use levers and have no problems.
Thanks, I've read that nitromors won't affect steel, is that true, if I leave the centre wheel and gathering pallet in place?
Hi Richard  It will remove paints, varnish Lacquers from many surfaces, I have used it on steel, wood and brass with no problems but you mut clean it all off thoroughly. I use warm soapy water then dry well to remove all moisture once done clean the clock in the normal way.
 Horolacq is what I always use on French Carriage Clock movements and cases. You need to get the clear, also a nice very fine paint artist brush flat style if possible. This stuff drys very quick, be careful not to handle parts with your fingers wear finger cots if you can.
The Harris MK1 clock mainspring winder is underway, photos to follow.  So far £0 but I may have to go mad and spend £20 to finish it. Hehe.
What's the best way of cleaning the bottom/ dial side plate?  Terminology?  I usually use lighter fluid followed by IPA, it would cost a fortune, could I use petrol, followed by IPA?
15 hours ago, RichardHarris123 said:
Might end up at £30, I'm going crazy.  Thanks for the help.
What sort of mainspring winder have you bought for £20 as oldhippy says they are not cheap, have you got the capture rings for the mainspring with it, what make is it and did you buy it from ebay?
Ok, after the conversation about quality tools!!!!
Not finished and very crude but it worked well. I attached the barrel to some wood with a plastic clip and held that in a  vise as a temporarymeasure.
The ratchet is removable and I can utilise different sizes of socket from the let down tool.
1 hour ago, watchweasol said:
Hi Richard   well done I like the design simple yet effctive, what did you use for the retainer, it worked well.
By the way I believe the watch (Half Hunter) is by A Schild maybe a 168 ?  inported by George Stockwell  who was a major importer at the time,  more to do.
Thank you, an advanced member like you appreciative it, means a lot.  Keep me updated on the half hunter.
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
