Beginners clocks
To work on clocks safely a spring winder is a useful tool when replacing broken springs, expensive to buy but quite sraightforward to make. If you need one I have the plans somewhere. I built two and a third partially done.   Cheers
As also are letdown tools for the removal of power again simple enough to make.
As Olh hippy said alarm clocks are a basic movement and not to be dismissed as training pieces. Although the mainspring doesn’t need a winder it still needs treating with respect as it can still give nasty cuts and the use of clamps is recommended.
Will look up the plans Richard, and pass then on.
Hi Richard,  just type in google  how to make a clock mainspring winder.  There seems to be a lot on the web now so plenty of designs to choose from.  a cheap let down tool is a metal tube with a slot cut in the end to fit over the actual key fitted into a handle , and by releasing the click and allowing the handle . to slip through the hand with enough force to have a braking action on the tube this will allow the spring to un wind under tension.  You may wish to purchase the retaining shells or a set of clamps or maybe even make your own shells as you need them/        cheers
A time piece with pendulum. You will need a mainspring winder. Most clocks have the springs in barrels apart from American clocks. Before I go any further I'm just going to look on ebay and see what I think would be best for you to start with.
Not much in just a timepiece. I have found these apart from one the rest are strikes but they are all working and not to expensive. I can help you with any of these it will not be a problem.
https://www.ebay.co.uk/itm/304830524278?hash=item46f950ab76:g:yYYAAOSw3-pkB2yx&amdata=enc%3AAQAHAAAAwAvPQit9ZbKPrlnlP2uJJnfwyxQLyr%2FIhkpDbk4DNLsQI%2FUI%2BtYPZ4yV4VHMwYi%2BkeX5xd%2BpGo%2BvDZxn8VVchcWSC%2B32PXaaxt2Y76CZx%2FejnYTVK%2Fe7I38P1YPdaMfdiIsETi1yixsK6%2Bd2i7YIHkOqgL4nOOOYw1L2c9piDkFsbx3rVNJ%2ByhS02GNpxgEghABwFUpHIjeWL8iANMiGo3%2Ba2h4B6mQ4Wi6h%2FWM9En67l2qzebZzTT9m7%2F8LyhVGRQ%3D%3D|tkp%3ABk9SR9bWwZ7fYQ
https://www.ebay.co.uk/itm/125825465653?hash=item1d4bc83d35:g:CoAAAOSwGV5kEvLQ&amdata=enc%3AAQAHAAAAwFaqfYJ87qWPVjv8haLw10p6bIk3M5CT6Yq3F%2BJIyf4jPsM8kV1z8rJ9WWQ9TcYPQ1e0bF0wgeb0JHk4gRqZD2v0a7W9xAZZFaCkZjDvDQ6Bp8IgRgovLQHnuWLTJo1JmtR09r%2Fy27pcy4Pbjte78d7CWz2llBqyAes5dpVz4aKmz4BMym10U0ucCiSMUXjyRXBqFcADfNhhJou56UNCFLP10nmqbptxFXPg2TmIz9kasGGfmyIT9KwlyePRJ%2FcSCg%3D%3D|tkp%3ABk9SR6LK_p3fYQ
https://www.ebay.co.uk/itm/404204572982?hash=item5e1c785136:g:dCIAAOSwGfNkEigJ&amdata=enc%3AAQAHAAAAwOJSDOHEVJUYcFo5EcbaWdD2vrecPtcawgOC7MBTshQ7W1uA%2BZC3abFdr2%2F2Oyzo7RJlZ5C0VTH9iEp%2BG1RDsyElSOv5Qse8INDAU9PNXl%2F3gDdd4S0VqrPBo2s4LOVc3TMmROWwJBZYRMY2%2BaCgdCEBLKoIf8QCSnwEBBzP3LULni4%2BjFPrzRCCGxYjF%2BuSDXjhqKFWC8da1GVLYJjPmoH61u59VogaZ7WKwt61TRbFUXjOJUqMZp6Txa2X%2BFTREQ%3D%3D|tkp%3ABk9SR97SnJ7fYQ
https://www.ebay.co.uk/itm/144990817418?hash=item21c2204c8a:g:qOYAAOSwa8dj~i5E&amdata=enc%3AAQAHAAAA4IcJCTuK%2BS87Ovzl7WFf6Qj7F%2BxUBDZ%2B%2FU2eCjXGUwOsoTrAhp5b5tzxqxgCA5dHAwi8nYlRPDjWCXsXAgkwVjfXyopbMsnayDumzUrkrM4z1CL9mQZ8aYuErT8LqfaH2AEvIbQFStIaTzEiu1%2B5gVThY7gmxh3VtVJv1ytAeKgFA1Tkz4gkIvxl%2FQCMuN4y2ACf9OzOKktmHeG6yhkX61GOTZtPr4JH6nH8TVcZq%2FpD17HwOYgR3mGZ6TrgALBTkEalaCD21wCg%2BR%2FFbZ%2B0RQ5IM0%2F3djGHeequVs7VXSbV|tkp%3ABk9SR-Dx2J3fYQ
Edited by oldhippy
Bought this one . £22.50. No doubt I'll need lot's of help but I'll do some research before asking the forum.
Hi all
Recently watched an episode of Repair Shop where the resident clock repairer Steve Fletcher whom is  certified repairer install a main spring in a barrel  by hand, which i have have myself, but only for my own clocks before buying a main spring winder. OI really don't understand how these programs can show bad practice.
40 minutes ago, Martyd said:
Hi all
Really? Which episode was that?
I know the feeling there are some butchers on Youtube, many should never be near a clock. The one that I'm always rattling his cage is someone called Scottie now he really is a test, he takes movements to pieces but never shows the actual repair then he films putting the movement back together, and he never replies to my questions.
Yes i know what you mean about Scottie, he always just takes them apart cleans them mentions about putting in new bushes, puts them back together and hey presto they are working even on a Westminister chime he recently worked on. And now he has members paying him.
The only person I recommend on Youtube is  Tommy Jobson, but he is for the very advanced clockmaker. You might like to take a look at what he does. I love watching him because a lot of what he shows is what I did many years ago. I'll have a look on the net and see what I can find. You can always ask me for help and advice I like helping.
Edited by oldhippy
I have received my clock. I know all of you will give me as much help as necessary but I need to help myself before asking for advice.  My first step is to learn the parts, next step to understand if there are any pit falls to disassembly, finally reassembly and case restoration.
Where's the best place to learn the anatomy of the clock?  Any pit falls to disassembly? Further questions to follow.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
    • Typically for introductions all you would have to say is hi I am interested in repairing watches and nobody's going to care about the technical details. Then to certain degree the introductions are not life or death in some cases I guess it depends upon what you did when you came to the discussion group. It's good that you're getting a balance complete for variety of reasons and getting a bonus balance bridge. Because I want you to pay attention to something when you get it as your hairspring still has a problem quite an amusing problem in a way. You notice your hairspring stud is a triangle or shape and it fits into a triangular shaped hole. It also notice how your hairspring has some weird bending right around the stud? So when you get your new balance bridge and the balance complete if you look carefully you'll find that I'm pretty sure the stud will be rotated and that they hairspring will come out the end not the way it's coming here you have managed to twist the stud putting it into the hole and that's why it looks so bad in the previous image. If you are skilled at fixing hairsprings which are not you can fix this. On the other hand are getting replacement so that's good. No it's supposed to be straight up and down. So in addition to twisting the stud you also bent it. On the other hand this is the most common place where people like to bend their hairspring and yes if you had practice with bending hairsprings this is all relatively sort of easy to fix. But I would really suggest practicing on another watch or basically scrap of balance wheels off of eBay that nobody cares about. Because practicing on something you care about really isn't the best. Then the reason I wanted the image below was to see how the balance jewel assembly is attached to the bridge. Sometimes it needed jeweling tool to push it out but in this particular case all you have to do is remove the U-shaped clip in the whole thing falls apart. But if you're lucky here replacement balance bridge will solve the problem.
    • I still need to see the complete movement as there are many types of Elgin movements. The part that you are holding is called a snail.
