Waltham Center wheel repivot project!!
Thanks Steven not something i had thought about, that might even work harden any stress points. -
Fully understood OH, not to sound negative in any way but life has a great way of screwing things up. -
An incabloc spring? About 10p at the current price 🤣
Have you ever seen grease spread? I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about. 9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it). If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
Polish it where the old part cracked as well. Get rid of the stress-raisers.
