Starting A New Tradition In American Watchmaking...
I hope this doesn't come off as a sales pitch for RGM Watches, but I find myself very proud of the fact that the USA, once again, has a legitimate Company making high grade watches. Since the doors closed on the Hamilton Factory in 1969 (the year I was born), there has not been a single company that has produced an in-house movement here is the United States.
I believe that, to us as American Watch Addicts, we have a special attachment to this company. And, I'm sure the UK Watch Addicts have the same feelings about watchmakers like R.W. Smith, who incidentally, I believe will go down as one of the Greatest watchmakers of all time!
I just wanted to share a couple of short videos that give the story behind RGM's momentous achievement of producing a great timepiece, the Pennsylvania Tourbillon.
Part 1
http://www.youtube.com/watch?v=4PrBLgjO0gU
Part 2
http://www.youtube.com/watch?v=QxrrHKTyxts
Regards,
Don
The American watch industry as was, had a past to be proud of, think of all the great names, Elgin,Waltham,Hamilton,Bulova, just for starters, I'm sure this new company will carry on the tradition. The only problem, being a poor person, will be the price, but then it's not aimed at my sector of the market. I hope they succeed.
Yes, their prices are why I don't have one today. If I'm not mistaken, there least exspensive watch is around $2000, their tourbillon is $95K!
I do lover their in house movement, the 801 caliber. it is probably one of the most beautiful  movements being produced today...
That is very nice! And yes - it would be a crime to hide it away in a case without a display back.
Also, I doubt these guys were the first to do it, but this is where I got the idea of using the Hamilton 10s movements for wristwatch conversions. They also produce some extraordinary engine turned dials as well.
I really admire RGM for doing this. I think with them and Roger Smith in the UK two of the most famous horological centres  are coming alive again and that can only be a good thing. Along with Seiko in Japan it is great to have other places of quality other that Switzerland.
I would wager that they are heat treated as is customary in this level of finish...but I don't know for sure!
As far as color, it can be controlled if you have precise control of the heat levels. If you've every blued a piece of metal, you can watch it go through multiple colors and in that, varying degrees of blue.
As far as imperfections go, if the piece is perfectly polished and cleaned, you can get an amazing Blue finish with really no visible flaws. But, it is NOT easy! Believe me as I've spent the better part of a day re bluing a set of screws for an antique pocket watch.
Speaking of Blued screws, that is the one thing about this movement that I really don't care for. Traditionally, blued screws were usually done on lower grade finishes and typically paired with guilded  movements. Polished screws were usually used with nickel finished or "white" movements...
Don
Don
The Blued Screws look "Right" with this finish!
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
