Watch becomes overbanked when in the dial up position. Runs perfectly otherwise
I have a watch that will run for hours with no problem when in the dial-down position, but when put in the dial-up position, will run for about 30 seconds before becoming overbanked.  It's not always overbanked, sometimes a gentle tap will get the balance moving again.  But other times it's totally locked up and requires removal of the balance to fix.
I had replaced the mainspring with a white alloy.  My first assumption was that the amplitude was too high, but a slow mo video showed that amplitude is only about 180 degrees.  The endshake of the balance is a bit high.  I can hear the distinct galloping sound when it's dial-up.
Unfortunately, it was tough to get a good shot of the pallet/balance when it was locked up.  What other photos could help diagnose the issue?
Edited by GregG
I don't think anything is wrong with the pallet jewels, other than the shellac looks strangely old and crusty.
But with regards to your roller table idea.  Is it because when it's upside down, the impulse pin might fall out of contact with the forked end of the pallet and guard pin, so the balance can spin to the opposite side without the pallet fork having bene engaged as well?  Then on the swing back, if it does contact the forked end, they're on the wrong side, so it stops dead in its tracks?
8 minutes ago, RichardHarris123 said:
A picture of the other side of the pallet.
Richard are you suspecting bent pivot on the fork?
Frankly, pallets look a bit misaligned too, repivotted, has had a hard life.
Edited by Nucejoe
40 minutes ago, Nucejoe said:
Couldn't open your vid.
Petersas makes sense, check all shakes in the escapement and pallets, ....  lock ...etc.
Is it adjustable banks?
High magnification is a must have in watch repair.
Good luck
Don't think the banking is adjustable, but I will double check.  I will remove the third/escape wheels later today to get a clearer picture for everyone.
I will take some pictures of the pallet fork.  Didn't seem misaligned to me when I had it off.  Could just be the angle of the photo.
36 minutes ago, RichardHarris123 said:
Yes, I've found that watches can run remarkably well in one position with broken pivots and not run at all in other positions.
Fork arbour looks shellaced in the hole , perhaps not a good friction fit,  so might not be perpendicular to the fork.
but either case both us are likely to have located the fault.
Rgds
I got some more pictures today.  I also got a video of the endshake on the pallet fork.  I forgot to take a video of endshake on the balance, but it seems very high (though the staff does not seem to be broken).  Not sure what to do about that since the jewels are rubbed in.  Also, in the first two pictures, I did my best to capture what the balance/pallet look like when it's stuck.  Interestingly, the jewel is on the opposite side of the pallet in those pictures.  The pallet fork is hung up on the roller.  Though without the escape wheel in the gear train, I think the pallet was free to swing to the opposite side under gravity get stuck.  Banking is fixed.
I purchased an inexpensive USB microscope that should be here tomorrow so hopefully I can take some better photos.
Edited by GregG
You can reduce the endshake by adjusting the cock, place a piece of aluminum foil in between the cock and mainplate, placing the shim near the outer premeter of the mainplate tilts the cock lowering its setting, move the shim inward /outward to get the perfect endshake. Keep an eye on the roller table, fork and  impulse jewel to engage correctly.
If and when the cause of the issue is found, it should be fixed accordingly.
Aren't pallet jewels usually bevelled on the ends?
On 2/27/2023 at 7:32 PM, Petersas said:
Pallet jewel needs adjusting
Or could be roller-table is to high .
Lets expand this a bit, the roller-table might be so high that impluse jewel passes over it, EVEN AFTER BALANCE END SHAKE IS MINIMIZED.  I would first adjust all  end shakes and see what else has the preveous watch destroyer has done.
5 hours ago, mikepilk said:
What does the pivot on the top of the balance staff look like ?
The top of the balance actually looks fine.  It's tough to see it between the coils of the hairspring, but the narrow point of the balance staff appears to be intact.
I will try the aluminum foil method today and report my findings.
9 hours ago, Klassiker said:
Did you adjust the end-shake on the pallet fork as well?
No.  I didn't know how to do it for the pallet.  I understand for the balance that shimming up one side would push the other side down.  But either way it's been running no problems, so if it ain't broke, don't fix it.
You would do it according to the same principle used for the balance, i.e. a piece of foil under the pallet cock, behind the screw, to tilt the jeweled end down slightly. As Nucejoe explained, the shimming is how you make reversible adjustments for diagnostic purposes. The permanent fix will be different.
In retrospect, when you say that, it was stupid of me to say I wasn't sure how to do it haha. 🙂
I last left it running dial up last night.  But if I come home today and it's still running, I am going to call it good enough.  I will continue to monitor it for a few days.  If it runs in all positions, I don't want to start fussing with what now works.
Good idea.
Good amplitude is the first concern now, in case its low, then  a close look at the lock on pallets is the next step.
Rgds
24 hours and it's still running!
Also there are two inscriptions on it:
Souvenir of the World War, years 1914-1918
1917
Joachim Zone
Jodoigne-Souveraine
Brabant
Belgique
1917-1918
Joachim (male name) in the zone of Jodoigne-Souveraine, in the province of Brabant, in Belgium
I tried to contact the local government of Jodoigne to see if they have any records of a Joachim who would be of fighting age during WW1, but the govt website is down.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
