Hello. I'm on my first assignment. Beha with a D202 movement. I've disassembled, cleaned. Enjoyed myself. However I am aware that this is a 'not ever in a chance will it work' project. It's just for my own experience.
I friend has asked me to look at his fathers watch, Swapped for a cup of coffee granules in Berlin 1950's. It has been looked at by someone who has attempted to get it going my rotating the balance. Hairspring is well and truly knackered. Movement screws missing. Can't believe the damage done by and 'expert'.
Regarding hairsprings? Are they specific for a balance. Is it possible to obtain a similar hairspring and fit it?
I have taken photographs, but they are poor.IMG_20230118_172541.thumb.jpg.afa0b90c3b721a342a145325a4d23f48.jpg
Edited by rossjackson01
It's not generally possible to replace just the hairspring. The hairspring and balance wheel are "tuned" together.  I think in this instance, a parts donor movement would be the way to go.
It may be possible to put that hairspring right, but it is a truly delicate process, and something you may or may not want to try.
@JohnR725 recently posted the link to this video,  and Henry Fried makes it look easy. He was, however, a true expert.
Yes he definitely was a very interesting person. I always think every time I hear his name I can remember the last conversations I had with him at a national meeting in Chicago.
That's a partially correct answer. If it's a flat hairspring that hairspring was vibrated for that specific balance wheel. Silly in general cannot swap flat hairsprings which is why there never listed as a spare part on a parts list.
If you have an over coil hairspring the over coil hairsprings typically are premade to very exacting specifications. Then the balance wheel is matched to the hairspring but the factory as a infinite supply of screws and conceivably custom makes the screws to exactly fit.
But over coil hairsprings are listed on parts lists along with the associated timing screws that you need to match them to a balance wheel.
Your hairspring appears to be flat. It does appear perhaps that those are timing screws but I'm not sure that they actually come off and I'm guessing in real life the best thing to do would be balance complete because matching a hairspring to your balance wheel is going to be very challenging. Or in general almost impossible.
I can't help but notice the elephant in the room.
If the existing hairspring is well and truly knackered as you say, then there is zero chance of doing damage to it by taking however many sessions you can stand and working on straightening it out. It won't hurt, and you'll probably gain significant experience, and the chances are heavily in your favor that you can make it better than it useta was and come out the other side with a bit of confidence boost even if you don't actually succeed.
Also, this conversation inspires a question: I constantly hear that a hairspring and balance are a package deal and one just needs to find a replacement. OK, maybe it's not trivial at all, but it's not like these paired up assemblies drop from the floating fairy dust left over from unicorn farts These are made by human people things. If you can get an accurate measurement of the spring wire cross section and number of winds, then it seems like a courageous feller could jump in with both feet and accomplish the task somehow. Why should watchmaking include all these many skills and tasks except for, dog forbid, replacing the magic hairspring? Honest question.
Edited by Vinito
See Fried’s book ‘Bench Practices for Watch Repairers’.
0D6041A9-A61D-4707-89B2-067CE2CA55CB.thumb.jpeg.1db6278a6b0f92e240bf7ffc1fad2e0d.jpegCBF7A01B-7594-4FDF-9C6C-4BE7BB27BB8A.thumb.jpeg.ecd53fb2e244a894c6414f647c1c78a4.jpeg
And this web site with great photos of the process. http://www.bobinchak.com/watchmaking/2017/4/26/hairspring-week-vibrating-the-hairspring?format=amp
Edited by JohnFrum
Watchmaking schools still teach hairspring vibrating, some more than others. The skill built doing dozens of them under expert instruction translates to everyday hairspring truing very well. The big issue if wanting to replace a spring is sourcing them. Way back in the day you could buy a packet of graded hairsprings from a supplier, in steel or more modern alloy. Today there are a few limited sources, usually with a small or oddball range of sizes. The manufacturers, Nivarox being the big one, don't want to sell a few springs; they want to sell thousands. You can usually negotiate for perhaps 100pcs, of one size, so there's that (but they aren't cheap). So one either spends time and money slowly collecting an array of different CGS numbers (the grading system for hairsprings), in both steel and Nivarox type alloys- though- often the steel ones will be graded in an older system!- and hopefully have some that might correspond to a given balance.
Then, really, you need a Luthy tool to count the spring, the link in JohnFrum's post above shows it well. These have reference platforms for specific frequencies, 18,000 being the most common. A different platform is needed for each different frequency (or- Frank Praezis above can supply an electronic platform that does any frequency!). Springs can be counted without the Luthy tool, but it's a miserable process.
You can usually reuse the original collet and stud if replacing a mangled spring, but it's nice to have an assortment of them as sometimes you may have no spring at all, or the collet is split, etc.- and there are many different sizes, so again, a lot of searching and buying and hoping.
Back when Fried and others were writing their books, let's say the first half of the 20th century, modern manufacturing methods had made replacement parts plentiful and affordable, so a lot of manual skills that were focused on in schools or apprenticeships faded a bit. But there were still many older watches, older being what we would call antique now, where no material is available at all. Thus the chapters on vibrating springs, or repairing fusee chains, and so forth.
Attached is a list of common CGS numbers and the approximate balance size they might correspond to, and a convienient conversion to the old system.
Edited by nickelsilver
Actually even way back then I guess depending upon the way back when was hairsprings were still available. No skill required other than to send it off and a new one would come back. I remember when I was in school we did that we needed a hairspring for something Off it went and then it came back brand-new.
Taking the bull by the horns. Can't lose anything.  This it. Was wrapped around the stub. I have disassembled, cleaned, assembled, lubricated the watch. Everything is fine. Final thing is .... spring eternal.
Movement is Durowe D202
Great fun this hobby.
Movement name
Update on balance hairspring straightening.
Tried to do the straightening using magnifying glasses. Too awkward. Duh! Use the digital microscope your bride got you for Christmas. Placed spring on paper and then on staking block. Better for vision. Metal block makes it awkward to differentiate hairspring and metal background.
Using two tweezers. Probably incorrectly, but watching and learning from Marks video I set about the repair. Gentle hold, gentle stoke. After 1/2 an hour, it's a little better, but i''m getting heavy tweezered. Almost went to bend it. Take a break.
As can be seen it is a little better, but long way to go.
too many photographs. Spelling
 Detach the hairspring from the balance, pin the collet on white sheet of paper/ cardborad, to have much more control over the peice.
Shaping a perfect terminal curve is challanging, call it good as long as the coil is centered and oscilator runs alright.
Rgds
Your oscilator would inevitably  be out of beat when you sort out the coil anyway, another task to adjust it in beat.
Rgds
Thank you Nucejoe. Good advice. However I have not yet got the skill to detach or to centre. I have ordered another movement to be able to complete the restore. This is my first practice at this sub atomic level. I do not expect it to ever work correctly. But it is good fun.
spelling
1 hour ago, watchweasol said:
Ross you have the paitence you just need to practice the skill bit and back off when tired or tweezerd,  have a beer and come back another day/ Its all about attitude, and as Joe said work on a piece of white carboard,     all the best.
Beer? Hic. Oip. Burp!
10 hours ago, rossjackson01 said:
Yes. Mark is right when he intimates 'practice, practice and more practice'
This is why I relate watch repair to an similar to being coming a doctor. Doctors always say they're practicing and were doing the same thing all of us are practicing every day we work on a watch.
21 hours ago, praezis said:
No balance Durowe 202 in stock, I am sorry. You may find it as Durowe 10 1/2, 410 or 412, too.
Frank
Thank you for looking. I have been able to source a d202 movement from Germany. Like you, the company has been most helpful.  The balance looks the same, but the configuration on the train wheels looks different. Will keep you all updated on receipt.
Regards to all.
Ross
    • I'm sure you will get help on here soon.  Kkramme we like new members to make an introduction before posting. A little about your self such as where you life and what got you interested in Horology
    • I'd be grateful for recommendations of good sources of advice on getting clocks with balance spring - as opposed to pendulum - escapements 'in beat'.....
    • Well I am in a bit of a quandary. I can't find the correct colour for the dial. I even wrote to Hettich a while back hoping they would give me the colour code for the dial. The reply that I received was "We don't make those anymore." I am thinking now to silver the dial and use a water transfer decal to put minute markers and the HETTICH logo (which is the very font that this forum uses) and the Made in Germany down the bottom. Not sure of the success rate of the water transfer method, but I have no other solution for the markers and logo. Handpainting is just not an option. In trying to get the top piece of the clock polished, it has progressively lost its sharp edges. My stupid hamfisted effort. I am thinking of purchasing a replacement piece of brass and drilling new holes in it for the corner posts. Why I attempted to repolish using wet & dry and not simply using a paint remover to remove the old lacquer from the brass, I don't know. You whistle and I'll point at the idiot. I also need to purchase some sheet spring steel as the two small ratchet springs that arrest the wheel that supports the weight after it is lifted by the electromagnet are worn. The two from the donor clock that I purchased are worse. I am hoping that I will be able to manufacture new springs without having to fiddle about with tempering etc to the steel. I have some ideas on that front. How many things until the clock is no longer the original? Like an axe. Heard a woodchopper on tv once saying that he had replaced the head on his axe twice and the handle three times, but it was the same axe that he began woodchopping with. 😉 I must post more often or read back through what I have previously written. Keep repeating myself. Sigh.
    • I use the exact OD and it fits in with a little force and a pleasing 'click' so it's snug and wont rotate within the holder, but that depends on how you have set up and calibrated your printer so you may need to play with the settings/dimensions a little to allow for any discrepancies in your printer calibration. PS I just finished (2 days ago) a new revision which automatically prints the movement OD on the bottom of the holder, I'll see if I can upload it here Here is rev 4 remember to change the .pdf to .FCStd so it will open in FreeCAD - also you may need to install the LiberationSansBold font and tell FreeCAD where it lives on your PC, or change the font to something you already have on your system. Para Movement Holder V4.pdf Examples below:
    • Only someone on this forum would ever understand the Oooooo I just did
