Importance of amplitude.
This part is dusturbing… The UK is no longer part of the Lugano Convention, whose rules Judge Green has applied, and as yet nothing permanent has replaced it.
I was not aware of that as I'm not familiar with the 861 calibre but I was speaking in general terms. Thanks for pointing it out!
Yes I have that in my watch list a JUF if cheap enough I will have a go , if nothing else it will be good for spares, I have a few JUF’s
Less give a damn- more **BLEEP** it! …nice that it is keeping time I’ve done a couple of these (one with your assistance) and there’s a third that needs work on the tension between what drives the hands and the barrel. Did you have any issue with that? …and I saw Ranfft make a small comment in a thread re: pin pallets- a couple drops of Tillwich blu, let it run down the pins. It is good for 20 degrees of amplitude… I’m using this oil as a cheat code on my unmotivated Venus chrono…
