Limit Movement?
I won a couple of lots and was a £6 add-on. Winding but not running. Limit has a few briefs about their history on their websites but after taking it apart I'm not seeing much about where Limit sourced their Swiss movements except Revue Thommen for pocket watches. This one only has the Swiss Made mark but not many other obvious clues...does the movement look familiar to anyone?
The back was mis threaded so I did the super glued flange nut trick and it worked like a charm. Mainspring is set and I'll set to work on the train tomorrow...
Edited by rehajm
3 hours ago, nickelsilver said:
This looks to also be a Thommen, imagining it's 10 1/2 or 11"', which it looks like.
Beautiful- thank you! It’s the 10.5’’’. I should have known- it’s right there on Ranfft once you know what to look for… I’m off to the races on this one…
Edited by rehajm
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
