Had about 20 watches stolen last weekend some of which did not work as i had not had time to fettle them but the one that hurt most is they had my grandfathers gold pocket watch which had "To Bert love Mollie" inscribed on the back.If any one see,s it on their travels  let me know please.
I can think of nothing worse than being burgled, especially when sentimental family heirlooms are concerned. Apart from the gold pocket watch, is there anything else we should keep a lookout for?
Sorry to hear that, never been done myself but my parents had a visit a couple of years back. These pondlife are like magpies - anything shiny - worthless or not. As clockboy & geo have already stated please post pics - they need to move this stuff, fleabay & similar are good places to fence stolen goods. Hopefully something may turn up.
As for the rest of us - try to take pics of any valuables you own, yes I know its a pain but it can help in these situations.
Sorry I'm a bit late with my comment on this. I do hope you can manage to get these items back. Many years ago the police would visit the shop I worked in with a list of nicked goods and ask if anyone had been in to try and sell such items.
Good luck with this.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
