Sellita Interview
1 hour ago, tomh207 said:
Watched that a week or so ago. It is really interesting and does rather clear up some of the myths.
Tom
5 hours ago, mzinski said:
An interesting Q&A video with Sébastien Chaulmontet of Sellita in which he answers an assortment of questions about Sellita. Worth a watch, especially if you think Sellita is a just a subpar clone ETA.
Interesting interview. So most of the ETA movements that we see and work on were actually assembled in a Sellita factory. And when ETA pulled the plug on them in the early 2000s when Swatch started to devise their evil plans to take over the world. Sellita pulled up their big boy pants, grew some, invested some serious cash and developed parts manufacturing based on old Patent expired ETAs that they had already been putting together for over 50 years. Well done Sellita 👏
Strange that nothing i have read about ETA has suggested that Sellita put their parts together for them, not by name anyway. I wonder why that is ETA ?
Tom
It seems Sellita have been popping up all over the place for quite a long time, either by pushing eta out of brands they supplied such as Breitling or because eta have been pulling back of their own accord. It nice to hear this young man Sebastian mention a few times that their parts and movements are available to anyone that needs them. After all you purchase something, you should have the right to repair that purchase yourself. Whether its a hoover, a washing machine, a car or a watch. Restricting parts take away that right.
It wasn't a case of Sellita pushing ETA out, but the other way around. Brands like Breitling and Tag Heuer no longer had access to ETA movements so switched over to Sellita. In fact, I'm working on one right now.
You'll also notice the question asked about the chewed up ratchet wheel issue on the Sellita movements and Sebastian dismissing it as an issue that's been resolved "almost 10 years ago". Well no sir, I have a 2016 Seliita SW200.1 with a chewed up ratchet wheel right in front of me. Take a gander over at Cousins and you'll see that ratchet wheel is a "Best Seller".
Outside of that, I really do like the Sellita movements. Even on their base SW200.1 the main spring barrel arbour holes are jewelled - I can't remember that being the case on the ETA 2824-2 (although I haven't worked on one in a while)
I read something about that, the tooth design was wrong, they supposed to have re engineered it and sorted on the 200.1.  Also beware of refurbished 200 and 200.1, indentified by a two letter code under the balance.
It was a statement I came across whilst perambulating the web some time ago, whether its true or not is a moot point, but I am sure if it is as I said it wouldnt be broadcast world wide for sure. Such information is usually gleaned from disgruntled personel through various means.  Many companies use the services of China and India to manufacture products under their name. An expose on TV showed that surgical instruments branded "Made In Germany" were in fact made in India in back street workshops. But EU law states as long as the steel was made in germany it was legitimate. an Independent tester found  up to 40% were not fit for purpose and were rejected on quality issues.
So what is the deal with ratchet wheel teeth?  This is a problem with the Valjoux 72 as well ( I have one with a busted ratchet wheel that I will finally have the balls to service it next year).  Seems like an odd thing to make such a vulnerable wheel.
Apparently Sellita modified the pitch of the teeth a little from the ETA design at the time. At least this is what’s going through the rumour mill; Sellita acknowledged there was a problem that they resolved in the above video but didn’t expand further. Personally I think it’s maybe a poor choice of materials for this specific part, as I’ve not seen this issue on any of the original ETA movements of the same design (even going back to mid 90’s ones). Your Valjoux 72 is muuuuch older so wear is to be expected. You wouldn’t expect it on a 2015 TAG using that Sellita movement. If I remember I’ll post some pics tomorrow.
it is not a Rumour that Sellita modified the Weels, it is documented by Sellita
look here
https://www.google.ch/url?q=https://www.sellita.ch/scripts/calibres/images/IS%2005_Evolution%20calibre%20SW200%20vers%20SW200-1.pdf&sa=U&ved=2ahUKEwig44XUqfX7AhVP4qQKHQw5DOwQFnoECAsQAg&usg=AOvVaw0QDdoNfkxEmBq3gOVDEgir
hope this helps a bit, i like Facts.....
regards,
Ernst
Thank you @Sirius. That document outlines the changes and updates between SW200 and SW200.1 done in 2008. I said “Rumour” because I’ve not seen confirmation officially, so thanks for pointing this out.
Thing is, the problematic one I have here is already an SW200.1 from a 2015 watch - so it would appear that the issue is still not fixed.
Lucky for you I believe Sellita dates its movements (at least mine for 2019, 2021, and 2022 are). Take a look next to the reference number to see what year your movement is from.
Also, if the watch had been serviced at any point,  there a slim chance that part got replaced with a bad part.
3904AA9A-0079-47B0-9A88-BE9701A39987.thumb.jpeg.25a7b8bf915fa3f2eda55b097a149bdf.jpegA5752096-9200-4653-BD1C-831CDD7775B9.thumb.jpeg.99c2377bd9b84d8b3e6007d967e0a596.jpeg7BA20B83-AB3E-4877-801B-BEA02864EB32.thumb.jpeg.e15efd4c938bebe1195ded6b45c5fead.jpeg
Valjoux 72/23 are known for losing teeth on the ratchet wheel. Not sure why, but there's a shortage of original replacements out there (I've made quite a few).
Yessir, here's the specific movement. It's a late 2014 model, in line with being in a 2015 watch. This is the updated version so technically the ratchet wheel issue should've been resolved already.
And the offending rathcet wheel. New one on the left, shewed up one on the right
Just for the sake of clarity, I don't want people to think I dislike the Sellita movements - quite the opposite in fact. Like with any product there are some potential issues to be aware of so me carrying on about it is to merely create awareness of the issue. Sellita parts are much cheaper (and more accessible) than the ETA counterparts so in principle I'd support Sellita if given the choice. They're certainly not some mickey mouse company.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
