Just Starting
Mobetter
Hi all,
I'm Bobby and I live in the Lowcountry of South Carolina. I have two young kids and a small business so free time is at a premium but I can still find a few spare moments to tinker in the workshop. I'm hoping to learn to service and fix strictly for my own enjoyment. I have a handful of old Sheffield type dive watches that I'd like to get back in working condition.
