Hi I'm new here
manjo
Hello together
I would like to introduce myself briefly. My name is Jonny and I am from Switzerland. Since childhood I am fascinated how a mechanical watch works. Now I am a bit older and have the patience and the skills to dive into this fascinating world. Unfortunately, there are no in-depth workshops near here and I would like to buy this online course from Mark Lovick. However, I am mainly interested in automatic movements and the course is only about manual winding movements. Should I still buy the course? I want to disassemble and reassemble an ETA 2824 movement. I work in the engineering industry and in my spare time I assemble micro drones. A steady hand and good eyes I have already as a prerequisite :-.)
Do you have any tips?
Thanks in advance
8 hours ago, manjo said:
Switzerland.
So you're from Switzerland where you currently located?
You're probably aware that when you start off in any field like the engineering field you don't just start at the top you start at the bottom and get the basic theories down as you work your way up.
So for instance an automatic watch is the manual watch with an automatic attached to it. Sometimes its integrated in all is one thing but a lot of times it's a separate attachment. So everything in Mark's course on mechanical watches still applies to the automatic watch. It just that you have to start somewhere and it's easier to start with the basic mechanical watch not having all the complications of the automatic watch.
Hello and welcome to the forum.  As mentioned by John,   Start with the basics and avoid any unesscesary complications in the first instance  and once you fully understand the basics its then time to move on,
witschi_training_course.pdf TZIllustratedGlossary.pdf
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
