New member from uk
Hi, I have a moment I need to identify to source a minute wheel for, here are some photos. The name on the dial is borrel and the only sign on the movement is "w" I think, no numbers under the dial either. I've seen it before but cannot remember
If anyone out there can identify it and let be know I'd be eternally grateful
Many thanks
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
