If you are like me and love clocks
oldhippy
I have been watching the videos that Dr John C Taylor has made showing the very best of some of the top makers we ever had.
Here is the link and you can them pick out what you would like to watch.
https://www.youtube.com/c/DrJohnCTaylor
I have to say he is not in my family tree but having the same surname at some point there is a connection
  • Thanks 2
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
