Today's movie tip: Radium Girls
watched it awhile back. tragic and fascinating at the same time. I have a few dollar watches that have the radium. I don't touch em and they sit in sealed plastic bags. you can really tell the difference when I hit them with a UV light. even some at 100 years old they light up like nothing we use today. I've been told you can work on them with gloves and a mask, in a well ventilated area. But to wash your hands and clothes after. nah. I'll just leave them where they're at to look at them.
good flick. .
I just Googled this topic and learned that "almost every watch between 1917 and the early 1970s used a form of radium paint", and that "the easiest way to tell if a watch is radioactive is to pick up a simple Geiger counter". However, the article also mentions other ways or hints to determine if a watch uses radium.
I didn't realize how dangerous radium is until I read the article and considering that many of the watches we enjoy working on are pre-1970s, I'm going to be more cautious in the future.
Here's the article.
Edited by VWatchie
It is true that our 'radium girls' developed cancer as a result of unknowingly ingesting quantities of radium. But 'other girls' have died from tobacco.
If you have a fine watch with a well preserved radium dial, such as my Longines cal 18.88Z,  relax a little and realse that you are in no danger unless you eat the dial.
Radium itself in the quantities used on dials does not glow. It was the incorporated fluorescent zinc sulphide that glowed. But over the years this has been degraded by the radiation. Perhaps into zinc oxide. I asked Dr. Roland Ranfft to do a little experiment by painting zinc sulphide onto the non-glowing ancient dial numbers and hands. The newly applied zinc suphide glowed giving the dial its original look. He now supplies activated zinc sulphide for anyone who is a good painter or who can outsource the work. Alternatively, the modern phosphors such as Luminova will also glow permanently, and more brightly than zinc sulphide, when applied to old radium dials. But the 'look' will be less authentic.
46 minutes ago, Jack75 said:
 Other girls' have died from tobacco.
We are all different mate and all prone to different diseases depending on our genetics. Cancers , heart diseases, respiratory issues, overactive immune illnesses,  underactive immune illnesses,dementias etc, etc.  Its about edging your bets mate, if cancer runs in your family then smoking is going to run your risk that bit closer. If heart disease then try to eat a healthy diet. Only fair to state the obvious that one person can be more susceptible to radium effect than another person. Precautions should ALWAYS be taken when working on old radium dials, but the risk of the individual should always be down to the individual and not influenced in any way.
So, was that done without first removing any of the old fluorescent zinc sulphides? I guess that goes without saying, but I thought I'd ask nevertheless.
The old zinc sulphide is mixed with the radium and cannot itself be removed. The fresh zing sulphide was just layered on top of the old mixed lume.
On 10/28/2022 at 12:25 AM, Neverenoughwatches said:
We are all different mate ...
Thanks for the genetics lesson, but off topic.
Sorry N-E-W, I was called away to dinner. What I was going on to say is that the radiation sensitivity to animals including humans (the LD50/30 - 50% die within 30 days) is species dependent (elephants are more sensitive than humans) but does not depend upon the genetic makeup of the animal. We can all safely wear radium watches whatever the condition of our hearts.
btw did the dog die?
🤔 are you saying that we all react equally to radium ?. Interesting . Lol no the gorgeous husky is having a crazy moment,  eyes open and teeth showing. 😄 . I may be wierd at times but why would i have a photo of a dead husky for a profile picture 🤷‍♂️🤦‍♂️🙄.
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
