My Junk Shop Find Waltham.
bsshog40
It is  Gorgeous pocket watch to be sure, but pictures! You have to post pictures! Just being melodramatic...welcome to the forum bsshog! Usually when fellas overhaul a nice find like the one you have here they post pictures of what they did along the way. I love Waltham, but don't have any American movement watches. Kepp posting!
JC
Edited by noirrac1j
Everytime I see beauty such as this, I wonder why they didn't have display backs.
I've sometimes wondered just the same thing. The display backs were used mainly by salesmen for the watch companies' retail outlets, but I've no idea what percentage of regular, ordinary customers would buy them. Perhaps they were considered too fragile for everyday working use.
  • 3 months later...
Pretty nice work for a watch made in 1901! I'm always amazed at what these american and swiss companies were able to produce considering they had limited lighting and power systems. Many of the factories at this time still ran on hydro power and sunlight! Just amazing. These Appleton Tracey grade Walthams are some of my favorites due to the mirrored wheels and the sunken balance wheel.
I found a couple of very similar Waltham movements while going through some stuff earlier. Funnily enough as a child I grew up right next door to the village of Waltham in the UK which is famed for its windmill and for its airfield RAF Waltham / Grimsby and former home to the 100 squadron. I'm guessing Waltham in Massachusetts derived its name from there and hence the Waltham Watch Company.
post-1462-0-48287800-1447699575_thumb.jp
post-1462-0-41962600-1447699583_thumb.jp
post-1462-0-86510800-1447699591_thumb.jp
    • Not SS but very slight wear on the underside edges have a little brass showing under magnification. New crystal arrived £3 with tax. Nice champaign dial color.
    • I also just realized I had that tech bulletin saved...but in French for some reason 🙂 No, I don't speak French. 2172_Bulova 11AOAC 11AOACD 11AOACB.pdf While parts are drying I'm on the hunt for a replacement crystal. I can measure the opening and get a generic one, but it'd be nice to find out what the original looked like first. Of course, case code 3093 does not appear in any of my reference materials. JulesBorel lists a C3093 case code, and shows Bulova part # 1222-5. Does anyone have information on this guy? I found a thread here talking about how the -5 is the height of the crystal, but that's as far as I've gotten. I also found one site that claims to have it in stock, but before I risk my $20 I'd like to confirm it's the right part.
    • Thanks for the replies. I did the job today and found that the oversized stem fitted just perfectly into the worn mainplate without any adjustment. Original stem diameter was 1.24mm and the oversized was 1.40mm. I did have to make an adjustment to the setting lever though. The small pip that engages with the groove in the stem hub was slightly to wide. I made that a bit smaller with a fine file. Don't ask me why that was too big, it just was. All working very well now. No wobble and not pulling out. New crown fitted as good measure.
    • Hi Vandan. Hi from a fellow newbie! Marshall has got a lot to answer for hasn't he! 😄. I also got hooked to this hobby after watching his videos.  Good luck with your journey to service your Grandfather's watch.   Nick
