My Junk Shop Find Waltham.
bsshog40
It is  Gorgeous pocket watch to be sure, but pictures! You have to post pictures! Just being melodramatic...welcome to the forum bsshog! Usually when fellas overhaul a nice find like the one you have here they post pictures of what they did along the way. I love Waltham, but don't have any American movement watches. Kepp posting!
JC
Edited by noirrac1j
Everytime I see beauty such as this, I wonder why they didn't have display backs.
I've sometimes wondered just the same thing. The display backs were used mainly by salesmen for the watch companies' retail outlets, but I've no idea what percentage of regular, ordinary customers would buy them. Perhaps they were considered too fragile for everyday working use.
  • 3 months later...
Pretty nice work for a watch made in 1901! I'm always amazed at what these american and swiss companies were able to produce considering they had limited lighting and power systems. Many of the factories at this time still ran on hydro power and sunlight! Just amazing. These Appleton Tracey grade Walthams are some of my favorites due to the mirrored wheels and the sunken balance wheel.
I found a couple of very similar Waltham movements while going through some stuff earlier. Funnily enough as a child I grew up right next door to the village of Waltham in the UK which is famed for its windmill and for its airfield RAF Waltham / Grimsby and former home to the 100 squadron. I'm guessing Waltham in Massachusetts derived its name from there and hence the Waltham Watch Company.
post-1462-0-48287800-1447699575_thumb.jp
post-1462-0-41962600-1447699583_thumb.jp
post-1462-0-86510800-1447699591_thumb.jp
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
    • Thanks guys.  quick question. For automatic movement, particularly this one. can I power down the main spring by pushing this rachet down?  i've gotten pretty used to SW210 and powering down a manual movement. But so far i've only been waiting for the auto movement to run out of juice before opening the case.
    • @Murks the problem you have mate is most watch cases out there to buy are for Seiko NH3X, ETA 2824 and maybe Myota 8XXX movements, oh also the big ETA 6978/9 movements which the dials start around 28.5mm. You might find one on a Google search but I suspect your main chance will be buying cheap quartz ladies watches and hopefully find one of the right size and condition that is acceptable. 😞   Tom
    • The anchor pin should be perpendicular when the anchor is sat on a flat surface and if you post a close up picture of the backplate I will be able to tell you the correct torsion spring , running fast or slow is usually wrong Torsion spring. Here is a video from my YouTube channel showing how I set the beat
