National Electric Watch Cleaning Machine
Hi
I have an old (very old!) watch cleaning machine that has recently been sparking a lot from the motor and cutting out. I took out the carbon brushes which are worn away - photos below. Given the age of the motor I don't see the point looking for genuine replacements, I thought I could get some generic off EBay or use some spares from another motor and shape to fit. I've no idea how long they should be though, and whether it matters providing they fit. Can anyone advise me? Thanks.
Stephen
With the colour and the timer in the base, It looks so like the Elma I bought recently. :)
It'll soooooon be Friday! ;)
Right on Geo, it's very Elma like in structure and appearance. I really pleased about the condition, almost "NOS" in watch terms. Can't wait for it to arrive.
And I can't wait until Fridayyyyyyyyyyy!!!
Arrived today, just managed to get home and catch the courier.
Unpacking is the best part
Cleaning up is the worst part.
I'm amazed and pleased with the condition, it really is as good as brand new, still has all of the parts and even the instruction leaflet.
With formal Retirement Day tomorrow I'm looking forward to this weekend when I can do some serious work with this.
post-1141-0-71725300-1435803389_thumb.jp
Well done Jim.
Of all the purchases I have made the best is without doubt the cleaning machine. I had an L&R refurbished *
Cleaning is now almost a pleasure. If I have a really dirty watch I give it a pre-clean first & it saves the cleaning solutions.
PS Enjoy your retirement
I bet you can't wait to get started. Have you got the cleaner and rinse? what are you going to use.  Looks a fine machine.
I'm ready to go, but don't have any cleaning fluid left. Got 4 litres of Zenith "Drizebrite" rinse and waiting on a delivery of L&R Extra Fine Watch Cleaner. But it has to come from Brisbane by road, 1,700 kilometres away, hopefully here tomorrow or Monday.
I looked at all of the wiring and it's an eye opener. Everything is well insulated (1950s style) and as we say in Oz, "built like a brick sh!thouse".
The three jars had a lot of dried residue in the so I put them in the dishwasher. They came out like new, all sparky clean!
I just hope Annie doesn't notice the slight chemical smell in the dishwasher, maybe I'll get one of those lemon scented things and slip it in there tomorrow  :D
More to come..............................
Did the same had to run the dishwasher with dishwasher cleaner to get id of the smell before you know who found out  :D
Saturday here, the other half was taking her God-daughter to the flicks so I had the place to myself.
I received the 4 litres of L&R  yesterday so this morning I charged two jars with L&R and one with the Zenith rinse.
I had a movement stripped down so I filled the little baskets (even the cap jewels) and started the test.
Ran 5 minutes on the first clean and spun off the liquid and then into the second clean for 5 minutes, and then on to the rinse for a couple of minutes and into the dryer.
Aside from seeing wisps of smoke coming from beneath the machine (immediate "kill power" enacted) there were no problems. I think the smoke was either some fluff and dust I hadn't managed to blow out or possibly some rinse dripped down onto the heater plate. I'll make sure I spin after the rinse a bit longer next time.
Final result?
All parts nice and clean (even under the 'scope) so I'm very pleased with the outcome.
My next test will be to clean a Seiko 6309 movement that hasn't see a screwdriver for about 30 years.
All in all, a good outcome.
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
