Vintage Homemade Crystal Press.............refurbished.
Geo
I purchased a cheap Chinese crystal press when I took up watch repairing/refurbishing a few years ago, this was one of the lever operated type with nylon dies. This has served me very well, but there are some jobs that a screw type of press is far better for because of the more sensitive control.
Being a canny Scot, I kept an eye on eBay for a second hand Robur or Horotec and stumbled across this antique home made press for £14 delivered.
The engineer in me immediately saw the potential, all it needed was stripped down, modified to take new dies and repainted.
The other thing that was required was a set of new aluminium dies, so after a search on AliExpress I purchased these for £26 delivered from China.
Right, down to business.
(1) Modify the lower die holder to accept the 6mm threaded alloy dies.
(2) Make an adaptor to fit the bottom of the ram with a 6mm thread to take the dies.
(3) Machine the lower end of the pillar to give clearance for the largest die.
(4) Accurise the dies to ensure that the faces are parallel. Many were slightly out of truth.
(5) Remove paint and rust from press, paint and polish.
(6) Reassemble.
Total cost of complete set £40.................well pleased!
  • Like 10
PS didn't know you had a lathe. Wish I had room for one
Wouldn't be without it CB, I also have a lightweight milling machine. I put together a machine shop when I was building target pistols many years ago, now it so handy for both my motorcycle and horology interests.
Looks great Geo, nice work. It reminds me that I bought a press very similar to yours meaning to convert it to take various dies I already have. You've inspired me to have another look at it, although I'll have to try and figure out a way to do it without the use of any similar equipment :). Not that easy when you're not particularly mechanically minded! Thanks for sharing.
Stephen
  • 4 weeks later...
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
    • Why just the bottom mike ? Is it worth polishing the whole arm ?
    • The one thing I took time over was to round and polish the curves at the bottom of the jumper arm. The slightest mark (left over from cutting of filing) acts as a stress raiser, just where you don't need it.
    • I printed the base and it is a bit too large to fit on the base of the hand setter. The ring bumps into the column so it is unable to full seat on the central ring. I'm going to try removing some of the materal and see if I can't get it to go down.
