Vintage Homemade Crystal Press.............refurbished.
Geo
I purchased a cheap Chinese crystal press when I took up watch repairing/refurbishing a few years ago, this was one of the lever operated type with nylon dies. This has served me very well, but there are some jobs that a screw type of press is far better for because of the more sensitive control.
Being a canny Scot, I kept an eye on eBay for a second hand Robur or Horotec and stumbled across this antique home made press for £14 delivered.
The engineer in me immediately saw the potential, all it needed was stripped down, modified to take new dies and repainted.
The other thing that was required was a set of new aluminium dies, so after a search on AliExpress I purchased these for £26 delivered from China.
Right, down to business.
(1) Modify the lower die holder to accept the 6mm threaded alloy dies.
(2) Make an adaptor to fit the bottom of the ram with a 6mm thread to take the dies.
(3) Machine the lower end of the pillar to give clearance for the largest die.
(4) Accurise the dies to ensure that the faces are parallel. Many were slightly out of truth.
(5) Remove paint and rust from press, paint and polish.
(6) Reassemble.
Total cost of complete set £40.................well pleased!
  • Like 10
PS didn't know you had a lathe. Wish I had room for one
Wouldn't be without it CB, I also have a lightweight milling machine. I put together a machine shop when I was building target pistols many years ago, now it so handy for both my motorcycle and horology interests.
Looks great Geo, nice work. It reminds me that I bought a press very similar to yours meaning to convert it to take various dies I already have. You've inspired me to have another look at it, although I'll have to try and figure out a way to do it without the use of any similar equipment :). Not that easy when you're not particularly mechanically minded! Thanks for sharing.
Stephen
  • 4 weeks later...
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
