Gap in between day and date wheel on nh36
Hey everyone I’m working on an nh36 and when I go to put the time at 12:00 (for the day/date to automatically change) the date wheel gets pushed to the right a bit, then it switches the date and goes back to normal. It’s not a huge problem but it kind of bugs me seeing a gap in between the two wheels at certain hours of the day. Anyone know a fix? Thanks!image.thumb.jpg.1afc6d28ff65cc46ecd60c3034e32afb.jpgas you can see there is space in between the two wheels on the side the crown is on
There is a gear is glued to to day disc. These are produced in Chine in huge quantities and quality control may be missing. Easily available from a variety of sources.
It took me a while to find an Arabic one and it was pretty expensive, do you know any sources?
  • Similar Content
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
