Crown wheel
Before a start I think I'm going to say thank you this website has been good to me for a beginner to learn appreciate how quick people respond to your question. Anyway a have this question my crown wheel screw is not holding in the hole I'm not sure if the hole is worn out or it just feel lose what can a do to resolve this?
Hi Murks. Just asking if you are aware that most crown wheel screws  have a left handed thread. Sometimes indicated by a line either side of the screw slot, not allways but when that indication is there you know it is definitely left handed. So that screw can occasionally get broken off or the thread stripped, i will assume this is what has happened hear. Post  close up photos of the screw and the threaded hole it fastens to.
1 hour ago, Murks said:
Yes I'm aware of that the have left hands thread a think it thread that's stripped but I'm not sure so I'm sending a pic
We cant tell from this photo murks. You'll need to get in close with a x20 loupe to fully inspect the screw and hole threads. If you are lucky the majority of the thread loss maybe on the screw and a new screw may provide enough grip to continue with your build. This is all providing that this is the original correct size screw. In watch repair always keep in mind that parts may not be original and may have been incorrectly used.
Edited by Neverenoughwatches
Is this the same Lip R25 that are working on?
In your other post, the cap jewels for the pallet fork and escape wheel are also missing. Looks like it might be more viable to get a donor movement than to attempt rebushing, rethreading and replacing the missing jewels.
It is the same lip r25 yes it not the pallet fork but the escape wheel has a missing cap and spring I'm trying to find where to get the spring and cap jewel that word fit the movement do you know any sites?
10 hours ago, watchweasol said:
Hi Murks     have a look at the site "speedtimerkollection.com" located in Europe and deals in second user parts also welwynwatches.co.uk  also second user parts.        cheers
OK thank you have put a picture this the incabloc spring I'm looking for the one on the escape wheel.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
