Bezel attach
SAMe
Hello all--new here--Retired airline pilot--------My question is-- How does the bezel attached to the case---I have a replica Rolex yacht master found--I have no idea who made it--but I decided to change the bezel face, so I removed the bezel---it is a rotatable kind----- There was a hole for the spring click--but none was there---that's ok as you can rotate either direction----but---now the bezel was a little hard to pry off----but now can't get it to attach to the case --sloppy loose---What held it to the case ?  It doesn't just snap on over a lip like some watches I had---real Rolex for example-----What is that slot around the inside of the bezel for ?  Driving me crazy to figure it out---any help appreciated--Thanks   SAMe
These are are snap on indeed. If your fake doesn't really, that just demonstrate its poor quality.
I was told there is a spring wire that goes into the groove in the Bezel ----to snap it on----it's not the click wire
I guess that might be as the bezel is just loose, but the case has a groove---Esslinger sent a flat spring washer---but that's not it   It was tight on there-- a little hard to rotate until I popped it off and maybe something fell out--looked but didn't see anything--- Anyway, thanks for your reply
Hi  A picture of the underside of the bezel and the front of the watch would be helpful in determining the problem.    On some bezels there is a wavy flat spring that fits under the bezel and then the bezel snaps on , the spring prividing the tension for the bezel.  There are others in which there is a small hole in the case with a spring and a bearing (a Biro ball is some time used as a replacement) which detents on the underside of the bezel.                thanks
Any clicking arrangement does not influence how the bezel is held to the case, which invariably is snap on. Check that the bottom of the bezel is all the way down to the case, if it was very tight to remove will need a good case press to be put back.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
