I am constantly losing parts. Last night I successfully fabricated a new click spring as a replacement for one I lost during disassembly. Today I decided to re design the spring and lost the damn click itself during re assembly. Are wooden tipped forceps better for not having parts ping out of the tips? It seems like I spend more time searching for lost parts than I do servicing the watch itself. Do I need a magnetic floor mat or do I need to work inside a sandblasting cabinet? I need some strategies please.
Unfortunately you learn how not to loose parts from loosing parts.
I picked up a great tip the other day from Neverenoughwatches.  I haven't gotten one yet but he said that back in the day, watch makers wore aprons and pinned them under the beach, draping it down in front of themselves so "most" of the parts that shot out towards them would land in the apron and not on the floor.
Don't get discouraged and remember they really don't just disappear...  With patience they can be found.
Good luck.
Edited by Shane
Pinging parts often happens because you are gripping the parts too hard - The chronoglide video demonstrates what happens when you do that.
Now that I have a light touch, every time my tremor acts up I'm dropping parts all over the place 🙂
At least the parts just fall down, much better than flying off into the unknown.
Ideally Magneto's dna, or Jacko's polythene bubble. 😆. All of the suggestions made are good. A magnetic strip would be great for finding parts in carpet. A good idea was made a couple of days ago regarding the strip from a shower. Or as another idea the magnet tool holding strips that you screw to the back of your garage workbench. On top of this a bright torch can often spot the glint of a gilt coloured watch part in carpet. Think of it as gold treasure hunting it may take away the frustration lol
10 hours ago, Kappa505 said:
This is what I settled on. It would be nice to have found something that had a 5x magnification built into the box.
That is what is used in a dental lab for sandblasting. There is a fan to suck away any dust and sand particles.
If you are using this at the moment, I suggest you get plenty of practice and master tweezering skills quickly and wean yourself off the blasting cabinet. It looks really uncomfortable to work in that manner.
That one is a lot nicer than the one I had in my office 🙂
For the OP, I don't think there is a need to put a movement inside of a plastic bag. You can get the same benefit by just laying a thin piece of plastic on top of the movement and working through it like the below. It works for all the movement springs like this click spring, shock springs, etc. Same when putting the springs back:
Edited by GuyMontag
I know, that's how I knew to look for one. It may or may not be comfortable to work in I will let everyone know my thoughts. I don't want to spend any time on my hands and knees looking for parts, especially since I am working on watches that don't have replacement parts readily available or detailed information about the movements.
Are you a dentist also? If this turns out to be a bad idea I can just take it to work. Plastic sheet might be the ticket if I do.
I'm an orthodontist. I honestly don't think this is a workable solution, or rather I should say that I don't think it would work for me but that doesn't mean it won't work for others. You can always give it a try and if it works for you then that's all that matters. For me, my concern would be that by forcing your hands to fit into the cabinet in a very specific (and limiting?) angle, it may be difficult to get the angle that you want for your arms/hands. But the bigger issue will be that high plastic dome on the unit will for sure limit how close you can get with a loupe. I don't see how it would be possible to use a 10X loupe when oiling or inspecting as your head would be bumping into the plastic dome of the cabinet.
Edited by GuyMontag
Exactly. You won't be able to work in a comfortable position. And when your body is strained, you'll tire easily and will soon lose focus and stability.
Someone posted a while back about using a photo-tent to contain escaped parts. That might work better than a blasting cabinet.
Yes there are many unknowns about if it will work for me or not. My main concern with it is if there is going to be glare from my headlamp reflecting off of the plastic dome. What I know for certain is that I can't be spending time looking for parts on the ground or trying to find replacements for these lost parts online.
I think the main job is to cultivate the skills where loosing parts is cut to a minimum, I tidy bench, clean work space and pars handling with tweezers  also fit a bench apron to catch any fliers. My bench is enclosed on three sides with glass panels and when i am of a mind I will make the bench apron as well.
This won't be a replacement for best practices in parts handling. Hopefully it will just minimize the downside when a part is inadvertently mishandled.
Tbh Kappa. No offence but you may be overkilling this. Every beginner experiences this, it is just a matter of practice,  patience and gathering old school tips and tricks to achieve better skills in handling. The part searching is all part of the process and becomes less frequent in time.
    • Instead of using tweezers, put a piece of rodico onto a toothpick or pegwood. Then set your spring to the rodico, this way the spring is not under any tension when floating it back into the bloc. As you bump into the bloc when trying to find the entrance the rodico will give but still holds onto the spring ie. You wont have the rigidity of tweezers.
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
