555 30-Day Clock (Made in China)
Gramham
Hello Everyone,
I am wondering if anyone has an experience dealing with this brand or type of clock?
I am hoping that it is a Chinese reproduction of a western design I could research and learn more about.
Thanks in advance!
g.
34 minutes ago, Gramham said:
@HectorLooi,
So wonderful!  Any paperwork on the movement at all?
Dare I ask about the existence of a tear down video?  🙂
g.
Sorry, no. I don't know much about this clock. I bought it off eBay just after the start of the pandemic. I had too much time on my hands and proceeded to restore it. It was pretty straightforward, nothing tricky. There wasn't much wear on the pivots or plates.
But you'll need a clock mainspring let-down tool and a mainspring winder. The springs in a 30 day clock can be a killer (literally).
But I know of a video on YouTube of a similar Chinese movement.
I know our resident clock expert on WRT, @oldhippy, will probably freak out if he watches this video again. Just remember not to follow what you see in the video. 🤣
You would be better of getting a Smiths strike and learning about that movement then something from China. I can tell you a Smith strike will last a lot longer then that heep, also you will be able to obtain parts for it.
