Ruhla Pocket Watch
1 hour ago, Loei said:
Indeed that is the missing part.
I'm not sure if that also causes the balance wheen to be unbalanced, I can find no reason why the top of the pivot of the weel is not touching the balance cock.
The parts are not bent or anything.
This begs the question, has this already been used as a donor for another watch. As a guess the bottom pivot is broken so the staff is lower than it should be to hold the top pivot in place or the top pivot is broken so not having a pivot to be held in place or both broken resulting in "The Wobbly Balance " With this issue then possibly a previous repairer or investigator has not wanted to venture into that repair or couldnt get a balance staff and subsequently robbed the stem and crown and also the pallet cock. These are the realities of buying pocket watches unseen, you pay your money you take your chance. I myself have just bought a beautiful Buser 105 WW2 military GSTP pocket watch for very little money. I very well expected it to have a broken staff pivot. Upon inspection this morning it did indeed have a broken top staff pivot. So now a 35 euro staff will be forthcoming. It is what it is, they are what they are 🤷‍♂️
27 minutes ago, Loei said:
I hope this helps.
Yep. Not much to hang onto on either end there matey.  At least you dont need the stem and crown now. Always a positive lurking somewhere .
Well, stem and crown are stil missing so will  be needing them ultimately.
Looks like I'll be looking for a donor movement with fingers crossed on a good balance staff.
You are carrying on ? Good for you fella. Sometimes if you ask and the seller has experience he may have a look at the balance for you and give you an honest appraisal of it. There is a seller i often buy from, he always quotes the condition of the balance. We could source you a new staff but if you need the pallet cock as well you may as well hold out and see if a good donor can supply you with both.
Well, now that you put it like that, unless I can find a nice donor movement this project will have very little chance of success.
So untill I can find one this project is going on hold. 😛
Sometimes that is what we have to do. I know there are guys on here that have had to wait a few years for something to come along. You were just a bit unlucky this first time, chalk it down to experience.  Even very experienced come unstuck from time to time, they will tell you that there is always something new to learn. I will assume that you didnt pay much for it and the knowledge you've gained has been well worth that. You still have a mechanical watch to learn from working or not. 👍
3 hours ago, Loei said:
I hope this helps.
The pivots are not broken. They are made like Timex pivots with tapered tips and therefore nearly unbreakable. The top bearing in the cock looks a bit disarranged which could be the problem.
I‘m sorry to say that this watch is not really worth fixing imho taking the overall condition into account. These watches were sold in giant numbers for very cheap in Eastern Germany before the iron curtain fell (and even cheaper after that).
5 hours ago, Loei said:
I hope this helps.
Yes both pivots are broken.EDIT. The are not, read below.
What you see is the body of the so called tampons which are fitted to the cylinder. Pivots are much, much thinner than that. Replacing them or the cylinder complete is no easy job because these would need to be custom made on the lathe. That is work for a good watchmaker.
If you want to learn watch repair I recommend that you avoud cylinder escapement watches and antiques in general, stick to what is recommended in our pinned topic
You are correct, thank you for making me notice that. I had never seen this construction, easy to to notice as there is no hole. The other cylinder mov.ts I have seen all have pivots and hole jewels.
Edited by jdm
Thank you kalanag, this is new information for me, I'm very curious as to how the cylinder is held in position without pivots. What an outdated idea considering the watch is only around 50 or so years old. It must be very cheaply made. I've always been under the impression that German mechanics were of good quality.
21 minutes ago, Neverenoughwatches said:
…I've always been under the impression that German mechanics were of good quality.
That‘s why I mentioned „Eastern Germany“ as the origin which was part of the planned economy of the uSSR from WW2 up to 1990 😉
Hi again, just wanted to check all your opinions on this pocket watch I just found:
https://www.ebay.nl/itm/184206202055?hash=item2ae38b94c7:g:FT8AAOSwKH1eQYTh
It says UMF1 in stead of UMF83 but it looks rather identical to the watch I currently have.
It also has the pallet cock
Would any of you say it is worth the risk to get it running again or just leave my watch for what it is?
Thanks in advance.
By the way, to my opinion the watch is a little bit on the pricy side for me, would this mean that I'm trying to jump into a to expensive hobby for me? I'm beginning to get the feeling that the prices for these old non-running movements are higher than I expected.
Yes it is a bit expensive especially considering these were the cheapest watch even when new, and probably there is people that gives them away for charity or to those that will take care of them.
The initial cost for a decent set of tools including timegrapher could be 300 GBP and up, it that's expensive or not depends on the budget and the passion of each individual.
33 minutes ago, Kalanag said:
Thank you, will keep an eye on that one!
It's not really emotional attachement, but I really like the look of the watch, it was the main reason for wanting to start with the Ruhla.
Well, maybe that does qualify as emotional attachement. 😛
Edited by Loei
I think I may need to disagree about this being a cylinder escapement.  1) it has a roller "pin" (rather than a jewel) - cylinders do not have those.  2) the staff does not appear to be hollow, but simply has a cutaway portion.  I think this is a pin lever with a bent staff, and the conical pivots are not great but could still be serviceable if burnished correctly.
I'd be happy to be wrong about it, but I don't think it is a cylinder.
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
