Landeron 148 chrono stopping
Hi everyone,
I am currently frustrated with this Landeron 148. It works fine with the chronograph off, but once it is engaged it stops shortly. I have checked for damage on the wheels as well as adjusted the dephting, but I can't seem to get it to work. I was wondering if anyone had any tips or can spot something that looks like it needs attention (photo attached).
The mainspring is fine I believe.
The adjustment on the sliding gear seems to be the issue as it stops whenever the chronograph runner engages with it. I can see that the depth isn't correct. I can't seem to figure out where the adjustment screws for the sliding gear are however.
Thank you, I believe that the adjustments on the driving, coupling and runner are fine now, but the watch stops immediately when the runner pin touches the sliding gear. It doesn't matter how I adjust it, the watch stops immediately as soon as the pin makes contact with the sliding gear. The sliding gear seems to work freely so I am really not sure why this is happening.
Sliding gear wheel and min.-recording wheel must spin absolutely free without the least resistance.
But your picture looks like pin and tooth are blocking each other. This happens if sliding gear and pin are not meshing deep enough. Adjust the sliding gear deeper with its eccentric (can't say which one, find which stops the movement of s. g.)
Frank
Thank you for the help Frank. You were right that there was something off about the minute wheel and sliding gear. I ordered a new minute wheel for a 148 and it was different from the existing one in the movement. It works fine now with the new wheel and I was able to adequately adjust the depthing. Perhaps someone had switched it out for a different Landeron caliber?
The issue I'm having now is with the start/stop/reset. I know that on these movements the 2 o'clock pusher starts the chrono while the 4 o'clock pusher stops/resets. However when I engage the start pusher it will only move the hammer to the "stop" position, not all the way out to engage the chrono. If I move the hammer manually and engage the chrono, then try to stop it with the 4 o'clock pusher, it will do nothing. If it is in the "stop" position it will return and zero it out however. I have attached a photo of me moving the fly-back lever and you can see it doesn't engage at all.
Not sure what the issue could be with and would appreciate any tips. The only thing I can think is that there might be a problem with the reverser spring and fly-back lever?
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from .
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
