Bezel Issue
Hi Guys,
I got a Tag Heuer here with a bezel issue.
The bezel just will not snap onto the case.
There are 2 spring under the bezel, the retention spring & a click spring.
I suspecting the retention ring is causing the issue, together with the rim on the case itself which seems to have some damage from previous attemps.
(I'll try to upload some images to make it more visual)
Anyone who has encountered similar issues? Any advice/tips are appreciated!
I've encountered a snap-on case cover which just wouldn't snap back on, no matter how much I used a case press. In the end, I sandwiched the case and cover between two of the plastic rings from the case press and slowly eased them together, bit by bit, in a circular motion in a bench vice. They snapped back together eventually with quite a crack.
However, the case and cover were in perfect condition - just very tight. If you have a slightly misshapen bezel or rim, it might be worth trying to see if the case rim and the bezel have deviations in them - and if the deviations might sit one on top of the other. Just a thought.
And as you say, the movement ring might not be properly seated.
Take of all springs out and see if the bezel fit the case properly . If it does test one spring at a time . The retension ring maybe needs some tweaking to make the bezel sit properly on the case . It should have 5 or 6 or more bends and they should protrude a little inside the bezel . Like on this Rolex bezel .
Edited by rogart63
Hi Rogart, That's indeed the approach I tried to take. But it just seems that the problem might be both with the retention spring's shape & perhaps also with the slightly distorted rim on the case.
I'll try to make some pictures of it, didn't get to it during the weekend.
Does anybody knows whether these retention springs can be purchased somewhere? I searched cousins but couldn't find them.
Have you looked at cousinsuk ? Under the Tag heuer brand .Watch parts branded ? An search for you specific model . Otherwise their is a company in uk that has .watchpart co.uk
Looked at cousinsuk and they didn't have any . Strange?  But the other has them .
Edited by rogart63
Thanks for all the suggestions. The bezel without the springs fits just fine. The click spring also seems ok. It really seems the retention spring which is causing the issue69c1ef1928e95f64cc1ff53aed4cc168.jpg522db594d4ea95ab97f0fdbd90baa9ee.jpg51e08f6ea20b528d6a526647215853f5.jpg. The shape is not ideal and it has very little tension. Guess a new spring is in order? I've included some pictures
Verzonden vanaf mijn iPhone met Tapatalk
The spring doesn't look to good . It doesn't fit properly in the groove . It could be bent back to shape but the easiest way would be a new spring . The shape of the edge on the watch looks ok to me . A few marks but that would not be a problem .
Bummer.... I ordered a new bezel spring at .watchpart co.uk.
After a long waiting time & inquiries from my side, They cancelled & refunded my order.
They can't provide me with the part.
It seems I will have to find an other supplier :-(
The search continues.......
I had issues with that company regarding a Tag bezel. They wouldn't answer phone calls or letters. I took advice from citizens advice and it took a legal binding letter to get my money back.
Tag parts are notoriously hard to come by, and after much eBay searching I eventually purchased a new bezel from someone in Florida.
That reminds me, I must put that watch back together again!
Hi Peter,
Looking at the pic of the bezel (leaning on the pad), the bend in the spring at approx 2 o'clock should be in the slot. As it stands, when you try to install the bezel it just pushes the spring upwards and not outwards.
Look at Rogart63's bezel, all the points are in the groove.
You need to tweak the spring a bit so that all the points are 1) in the groove and 2) lays flat. Once you get it looking like Rogart63's, then try installing.
It should be an easy fix... easier than adjusting a hairspring at least!
Anil
    • I think if you want to play Billy big b.ollocks then you have to have something up your sleeve, anyone that knows how to fight, plays dirty. Lets face it a lot of folk that voted for Brexit just rolled uk their sleeves to say up yours EU hoping for good changes. We have idiots for leaders and probably none of them clever enough to clean the shitty stick they were given. I didnt vote, what will be will be.
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
    • Hi, I’m constantly asking my wife to help me with removing the stem in order to complete casing. To expand, this is not a challenge for me when the setting lever is secured by a screw (older calibers). However when the setting lever is attached to a spring loaded setting lever axel, like on more modern calibers, I simply don’t see how to apply enough pressure on the button to get the stem out short of putting the movement face down with the dial and hands attached, which I’m loath to do in order to avoid damaging the dial/hands? what technique should I be using? thanks
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
