Cartier Santos--is it a fake
it looks like a fake
I'm inclined to be a little suspicious too.
On all of the Santos dials that I have looked at one of the strokes of one of the numerals is the word "Cartier". It's not always in the same place, on yours it's on the thin arm of the V in VII, and on yours it appears to be very smudged. I can't imagine that a genuine dial would be anything other than crystal clear. Check images on the www and you'll see what I mean.
  • 5 months later...
I found this comment on Chrono24 about the Cartier ETA 2671
Movement complete, for the Cartier Santos ladies Automatic. This is a complete movement, without it's hour wheel, but the caliber is unknown. As this movement needs a hour wheel, that has a reduced size, kindly check if your hour wheel replacement is available before ordering this item. How to know it is a Cartier caliber? Simple.. LOOK at the regulator portion of the balance bridge, the regulator will be left handed, ie: the reverse of all ETA 2671 calibers. This is a normal Cartier trait, to have a left handed movement, it simply cannot be replicated!
I do not understand the "left handed" comment.
  • 4 months later...
    • So I just wanted to say "thank you" again.  The angle is the key bit it seems and yes, it did basically just fall, or float, back into position when I got it lined up just right.
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
    • Hello Horologists, thought I'd introduce myself. I'm a 50ish year old who has been dabbling in watches for a while, did a couple of BHI course here in the UK and have started to dabble at bit more. I also took the level 1 course, which was a good refresher. Now off to look at some Bergeon tools and then buy (and regret buying) the cheaper ones...    Stirky.
