Making A Watch Bushing
clockboy
Find below a vid on making watch barrel arbour bushing. Interesting techniques with the graver especially how he uses the graver to get a dead parallel cut. Noticed though the final drill (when it parts the bushing) does not go completely through hence the broaching required for the final, final fit. This technique is how I make my custom bushings for clocks.
As an engineer, it never fails to amaze me seeing gravers used like that. It looks more akin to wood turning than metal turning. I still use a cross slide and tailstock, just because that's what I know best.
The part that he makes look easy I struggle with Is the parting off. I always have to turn the almost finished bushing around & finish this part to get a nice finish. I wish I had a tailstock I could rely on (mine is out end to end & touch) then centre drilling would be so much easier.
    • the problem with vintage watches and yes quartz watches can be vintage is availability of parts will be a problem. I have a link below where we can cross reference the coil and  I was hoping for more. Another problem for vintage parts are everyone on the group gets used to ordering from online. Conceivably the physical material houses that still exist out there might have the part and you'd have to reach out to them and see if anyone has one. this is because they don't list every single part that they have online with the exception of cousins where everything they do is online work just doesn't exist but the other material houses can have stuff not listed. Otherwise just set up a search on eBay and sooner or later it will possibly show up if you're lucky.   http://cgi.julesborel.com/cgi-bin/matcgi2?ref=SEK_6020A
    • Hi welcome to the forum.    Enjoy
    • the bestfit book refers to Revue as wittnauer and the fingerprint we have this.
    • Maybe a little off-topic, but it still amazes me that most people (and myself before I got into this hobby) don't realise that the movement of their watch was (in most cases) not made by the name on the dial of the watch. This is especially true of many 'fashion' watches which use the cheapest of cheap movements ($4 each) which are completely out of proportion to the overall cost of the watch ($++100s). Usually the actual manufacturer is stamped somewhere inconspicuous on the movement, usually around the balance, and this is what you need to find so you can locate spare parts or servicing manuals etc. This is like buying a top of the line Rolls Royce Phantom and learning it has a BMW engine..... oh wait a minute, it does! (6.75-liter, 460-horsepower BMW V12 engine - reference)
    • I have an image of what the case is supposed to look like disassembled. then an interesting website https://www.mybulova.com/vintage-bulova-catalogs there's all sorts of interesting things here for anyone in watch repair. but for the particular subject these are the two I recommend. You can see page 7 is where I got the image of the case. Then the word apartment technical manual is really a training manual of watch repair covers wristwatches and pocket watches everybody should have a copy of this.
