Hi everyone!
Hutch
Hi everyone! After spending a decent amount of lockdown getting absorbed in watch making and repairing videos online I’ve got an order of tools and oils arriving today. My fascination started after being gifted several vintage family watches, including a beautiful Waltham pictured below.
I’ve found a pocket watch with a working Unitas 6431/6445 that will be my starting point, and will hopefully be able to move on from there.
Cheers, Elliot
Edited by Hutch
Updates movement No.
That's a beautiful watch Elliot! Welcome to the forum! Quite a few folks here probably fell into this via YT videos during lockdown. We have our share of experts too, so crack open that Unitas 6431 and let us know how you're making out (and don't spill any of that oil, it's too expensive).
Hi Elliot,   Welcome to WRT forum and good luck with your forey into horology.
6 hours ago, Hutch said:
I’ve found a pocket watch with a working Unitas 6431/6445 that will be my starting point.
 Your best option for a start is a scrap 6431 unitas, it'l also be a material house in your drawer for spare parts you may come to need when your pocket watch gets on bench for service.
Good luck pal.
    • OK! I was able to get a nice set of timing washers from ebay! And they worked really well. I needed to slow down the movement by about 6min and I put four (=two pairs) of 3-minute washers (rated for the the size of the movement) and it did pretty much exactly that. On one pair of screws, there were already washers. So I added a second washer on those screws. Maybe not ideal, but it doesn't cause any problems. Poise is ok.. not perfect.. but I had so many issues with the watch that I decided to accept it. It's a 90-year-old watch. Delta is around 40 seconds.
    • I think it is friction fit, there are tools to remove them, cheaper versions are available. You could try adapting some pliers, see my crap drawing.  The pushers are available in various sizes, you could measure once the tube is removed.
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
