Hi All,
I am quite new to the watch repair world.  Aside from eBay, are there other online places were one might find parts specific to a watch movement.  I recently posted about a main plate in which I screwed up a gear post because a screw had broken off.  I would like to obtain a new main plate for the same watch (Montilier 60).  Is this a movement that is so old that I am dreaming?
Thanks in advance,
Don
I have ordered from Cousins but so far as I know, they don't have movement main plates, right?  Same goes for the other recommendations.  I am really wondering if I am not clued into how others may be finding "hard to find" components of watch movements?!  Perhaps this is tribal knowledge that is mostly not shared?
Manufacturers didn't and don't make the main plate available as spare. That may or not make sense, but so it is.
Have you considered that it can be that others either buy a donor watch (searching and waiting for as much is needed), or may never get the part alone. The other possibility is that skilled watchmaker make or adapt what is needed by themselves.
Surely not. There is no secret place for parts, everyone  can  make the same online searches with the same results. And for those that have parts to sell best and fastest way is online as well.
Nowadays more than before, if you bring a broken watch to a professional repairer, the answer will be that he can't repair it because can't get parts.
Edited by jdm
You must be patient.  Watch ebay daily for a donor.  It may take two days or two years, or maybe never,  Join NAWCC forum and ask there (I have had no luck there so far).
As @jdmsaid, you may have to adapt what you have, or ask a watchmaker to do it for you.
No need to watch, just set a  new llisting notification (using an external website or app may be more efficient that Ebay itself). That, and bid sniping services, are serious buyer's best tools.
As it happens, watch repair is an hobby or profession that requires a great amount of patience, both at bench and not. But I guarantee that there will be always something on the bench waiting to be taken care of, while you're waiting for other parts or tools.
Edited by jdm
" as far as I know" - so you haven't bothered to look ? You have to make some effort to find the more obscure parts !
Cousins do sell mainplates (just type "mainplates" in the search box), but not the one you want.
Finding a donor movement on ebay may be your best bet.
Indeed!!  I weep daily over my Cyma 571 begging for a balance complete (or hoping to muster up enough courage to make an overcoil from my 571 planar hairspring that I bought).
Likewise - whilst trying to fix the overcoil on the hairspring of my Universal Geneve Cal  267, I released the tweezers too early and trashed the whole thing. Had to wait 2 years before I found another movement I could use the balance from.
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
