14 minutes ago, markr said:
Bought a lot of tools and now it's time to play what the hell is that?
#1 looks like the worlds most complex case back remover.
I love the movement holder, i nearly won one just like it on ebay the other day but my bloody phone crashed at the end. I was rather pissed off   about it 😤
A nice easy hand one as well to make up for it. Mine has never failed me yet. Oohh pivot drills and holders, roller remover, hand remover, cool looking pliers, a cuddly toy, a teasmade, a and set of matching pans. 👍
Edited by Neverenoughwatches
1 hour ago, markr said:
Are you ready for round #2 ?
A ? At first i thought some kind  of lapping wheel, thought the stud was an arbor, but no. B - a staking block ? C - homemade tool.  D- are these reaming tools ? Countersinks. E- a vice for hand broaching ?. F and  G - for turning a balance staff on its balancewheel for repivotting like a jacot.
May not all be correct lol. Based on tools that  I've seen similar.
34 minutes ago, markr said:
A. Looks like soft leather for the inside of crystals.
What would this be for ? Watch repairers make all sorts of home made tools to suit how they work some of which can only be guessed as to their use. As soon as I started repairing I was doing the same. I come up with all sorts of crazy ideas. Some work some don't 😉
Just trying to be funny here, but #3 looks like the end of an old wooden crutch that was cut down and threaded at the top =D
Good examples of overengineered and under-engineered.
Love seeing cool tools and figuring out what they are used for. Thanks for sharing, Mark!
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
