Diagnosing a faulty platform escapement.
clockboy
Another update the ships clock.. It was fiddle day today to find out why one of the  platform escapements was not running. This is how I diagnosed the fault. Assembled the spare movement after repairing one of the old springs. Then I test the train of wheels no fault found but the platform refuses to run. The next stage of analysis was to identify what part of the platform was at fault so I removed the hairspring assembly and low and behold the escape wheel would not turn.. This was the area I suspected yesterday. Removed the pallets assembly and still no action under microscope found the bushing that supports the escape wheel was badly worn and was binding. (See first pic)
The bushing hole required was 0.28mm and I used a french clock “Bouchon” see some on my desk in the second pic. The hole for the bushing was 0.80mm. The hole for the bushing was made with a small cutting broach. I used my staking tool to push the bushing in and I used my Seitz jeweling tool to adjust the end shake.
It is now on my bench running just fine.
Next job try to refurbish the dial😏😏😀
Edited by clockboy
Without reading the full explanation I would of said check the depthing of the escape  wheel to the third/fourth wheel,I’ve has exactly the same problem with a French drum cylinder movement and found the depthing to be incorrect due to large screw holes on the platform itself.
Getting the depth correct from the  contrite wheel to the escape wheel is vital. Always a good thing is to mark the platform before you remove it. Many movements also have a depthing screw for the contrite wheel before removing the screw take note of how many turns it takes to unscrew it form its plate.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
