seiko 5856 regulation
Hello!
I have a 5856 that is losing time. I opened it to see if i could adjust it slightly, but i cant figure out which screw to turn, or if it is even possible on this movement. Can someone maybe point me to the right screw or tell me if i am wasting my time?
It probably needs a clean and lube. Check this for more info.
On 2/5/2021 at 3:22 AM, mzinski said:
Does anyone have a King Seiko Caliber 5856 service manual? Or one for a similar reference?
I have a King Seiko I'd like to clean up but I'm hesitant without a technical document.
Thanks!
Excellent! thanks alot! do you by any chance know if + is clock wise or counter clock wise?
Absolut beginner here i might add, thank you for your patience!
Edited by jpg
Mark or photograph the current position and then try. These trim capacitors typically can be rotated all way round and have one position for maximum capacitance. Either way you go from there will reduce the capacitance and speed up the watch.
Edited by Kalanag
1 hour ago, jpg said:
Hello!
This will regulate the timing. Servicing it will also help, the rotors can get quite clogged up with wear debris. The train wheels are very tiny so be careful, also the rotor can be a real shite to place back with being magnetic. They want to stick to everything and jump around. There is a little trick that helps with that though.
All of this is based on my hobbyist experience.  Seiko quartz of this era came pretty highly regulated.  They were designed in the mechanical watch era, with mechanical watch parts, and were meant to be serviced.  If it is loosing that much time, it needs a service.  I have serviced a few 754x movements that were loosing significant time.  Without adjusting the trimmer, they all came up keeping time within seconds a month after servicing.
I would not touch that trimmer screw until you have serviced it.
    • An incabloc spring? About 10p at the current price 🤣
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
