Waltham 8s
Hi everyone have got this waltham 8s 1873 I'm looking for the fourth wheel a looked on ofrei and daves it doesn't seem to have one does anyone know where else a could look?
In the USA, you could try:
https://www.jewelerssupplies.com/
or
http://www.julesborel.com/
Cousins in the UK might be a possibility (although Waltham is a US watch, I'm sure some of them made it across the pond).
https://www.cousinsuk.com/
Mark also has a list here:
https://www.watchfix.com/category/watch-parts-tools-suppliers/watch-parts-tools-suppliers-us/
Finding a another movement broken off of eBay might be your best option. It be extremely unlikely to find anyone stocking the new component and then if they did which fourth Wheel did you need as there was more than one.
Each of the American watch companies all seem to have their own interesting takes on spare parts. Waltham like to have lots of variations. Although they do have exact part numbers for each of the parts but as you can see from the image which fourth wheel do you need? Or is in situ watches that had different plate styles that was also common
Then just in case you don't have the material catalogs that has your watch at its parts there is a link below or you can download it.
https://archive.org/details/catalogueofwalth00walt
3 hours ago, Murks said:
'm looking for the waltham size 8 model 1873 with 3-4 plate I know you said ebay the best option let me know if you know anyone.
It would've been helpful if you gave us a serial number.
You didn't study the pictures did you? I don't think I was clear on explaining so I've snipped out the images separately and I will explain the problem because you still haven't told us which wheel you need?
One of the problems with watches not just American pocket watches depending upon how long they were made for there will be variations. Some components in the watch the variations may have separate part numbers other times they would use the exact same part number and you need a description on the part number this would typically be a balance staff. Then American pocket watch parts were made in batches which means there may be variations depending upon what it is you need.
At the time the catalog was printed and 1911 material houses would never stock all of these components. They would order from the factory unless it is for something extremely popular or was a popular component to break like balance staffs.
It does not look like the played style determines which fourth wheel you need as that's not used in the description.
You will see for this watch there were two separate wheels. Now this is the wheel with out pinion just the bare wheel you determine which one you have by the number of teeth.
Then there are three separate pinions but if you read the description they specifically go with specific wheels it's not like you've a mix-and-match option.
Then when their combined together it appears to be that the 70 teeth wheel did have two separate pinions and the 82 wheel only had one opinion. So basically there were only three separate fourth wheels for this watch. To get the correct one for your movement you will need to know the number of teeth and if it's the 70 version then you need to figure out which pinion you have.
Then here's a company that does have stockings of some vintage components and the second link he has movements including your movement. Usually if I need to get spare parts of this vintage I end up cannibalizing a movement as I don't actually know anybody who stocks hundred-year-old parts .
 https://www.daveswatchparts.com/index.html
https://www.daveswatchparts.com/WalthamMovements.html
Thank you sir I understand a bit I'm quit new to watch repair this is the serial number: 2125977 for the movement have already contact daves watch he told me that sold all he's 1873 waltham movements and parts to a customer.
The reason I wanted the serial number was for the website below.
The reason I wanted the serial number was for the website below. You can look up information about your watch. You can find out that yours was one of 100 in that batch which is a really small batch use of the batches are bigger. Then there's the total quantity of watches made and you can even find out by clicking the model number how many of that probably made etc.
https://pocketwatchdatabase.com/search/result/waltham/2125977
Then it's not mentioned above but both Waltham and Elgin exported heck of a lot of watches out of the country. They had a sales agent in United Kingdom in several other locations. Which means you can look at eBay UK for your watch you'll just have to spend some time looking. That's a unfortunate problem of vintage finding parts can be a challenge in finding a month eBay can take some time. But at least there is eBay and the parts can be found or the movements can be found eventually.
Then if you really desperate there is another option. You should bill a find some way doing an equivalent service in United Kingdom there won't be a lot of people like this but they do exist that is somebody can replace the damaged component make a new one.
https://henningwatches.com/index-2.html
1 hour ago, JohnR725 said:
I want to say thank you very much mate you are brilliant that has helped a bit
One more question  sir what if the pocket watch is a UK got this movement called 77cornhill &230 regent St. London in walker serial number  is 20438 how do a find this on the database?
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
