1970s Omega Speedmaster damaged
Greetings,
I've recently acquired a vintage Speedmaster that has some unfortunate damage to it. See a video of the damage at this link:
https://imgur.com/a/rGWQG4K
I'm struggling to see what's actually been damaged here, if it's part of the dial or something else (tension ring?). It's under the glass right on the edge of the dial (see image).
Would love to just know some more on this, what's exactly damaged, if it's an easy change (e.g just a replacement or fix)
Thank you.
5 minutes ago, Watchguy2 said:
Greetings,
Thank you.
From the second photo does look like a broken tension ring. Does the crystal feel secure ?
Yep, feels secure!
What does this mean?
Edited by Watchguy2
I'm not sure I've ever seen a broken tension ring? Now it could be a broken poly propylene or whatever the plastic gaskets are that holds the crystal in place they can disintegrate. The normal tension rings: the inside their metal and I don't think I've ever seen one go bad but this is watch repair everything is possible.
Then I didn't see any back pictures like a picture of the backside where we can get a serial number or a case number although usually case numbers inside the back but serial number would work I can look up how the crystal holes in place but I can't do it without a number.
Thank you john. I do agree the tension rings i have come across have been of a mild type steel so are more inclined to bend as apposed to a hardened brittle steel that would fracture. So could this be of a non tension crystal type fitting ?
No identifying numbers on the back besides the strap.
Problem is I went back and looked at the pictures and it's really hard to tell what were seeing. Although if it was a plastic crystal it would have a tension ring. If it was some form of glass or worst-case sapphire because Sapphire would be astronomically expensive then there would be an outer Polly propylene ring holding the crystal in place typically.
But the best way to do an evaluation is to take the back off the size we would get the case back number from the inside. But taking the watch apart does bring up a minor problem like?
Recently acquired was it expensive? Casually one is looking for a crystal the seems to be an expensive watch I wouldn't really recommend it for your first watch repair. Even taking the movement out could be interesting if you've never done it before and Omega watches the parts are astronomically expensive if you can find them. As they have restrictions on who can purchase those parts.
Thank you for that information. I have been looking at ebay and drooled over an Omega as an idea for a future project when I have experience. Thank goodness I saw your comment.
Regards
Ross
It was a gift and came as is. Is it something I could send off to get serviced and they can fix it then?
Dont know if I'm prepared to open it myself
Edited by Watchguy2
You would maybe want to weight up the cost of having it repaired against leaving it as it is and just being careful having it around water as the broken seal tension ring ? will affect its water resistance. Tbh i would never have water near a vintage watch full stop. But as John says too expensive to try to repair yourself without any experience .
I wouldnt open it yourself. Not without a good amount of learning and experience under your belt.
Edited by Neverenoughwatches
Thanks for the information. At least I know it can be fixed if necessary. Will have a think
The bracelet doesn't seem to match the watch, it seems far more modern. Do you know much of the watch’s history?
Depending upon the country you live in you may have a Omega/Swatch group service center. I have a link below it talks about the servicing of you send the watch in it is completely restored the movements restored faulty components are replaced the case is stripped refinished everything is you basically get a brand-new watch back.  But then there is the problem this isn't a cheap watch and the servicing is not going to be cheap I used to think they had the price list on the website but I don't see it there probably because too many people had a heart attack and were unable to send their watch in. Although considering what you get and they have original parts it is typically a good deal it just isn't cheap
https://www.omegawatches.com/customer-service/interventions-and-prices
If the crystal has been replaced with an aftermarket one the original ring could have been cut to reduce its diameter, an original crystal should have the Omega symbol in the middle.
Parts are availabel but pricey and you need a friendly watchmaker to get it for you.
Anilv
Anilv
A replacement crystal would come with its own ring wouldn't it? It's probably just a generic type that's too small.
The last Omega crystal I bought had a ring inside but that was for a seamaster not speedmaster,
Anilv
Anilv
Crystal is original. If I get it repaired, would they need to change that?
Edited by Watchguy2
I don't suppose you've got specifications for your watch? Like what kind of movement is in that case for instance?
All you have to do is take the old crystal out you would have to have the case number to get the proper Crystal. The crystal of this type is listed as a Plexiglas crystal with a black ring. You would just need a crystal press to the right type to push it in.
Plastic crystals have a lot of stress and this will eventually show up as a lot of hairline fractures on the crystal. If you are saying you want to save the original I would recommend not bothering they are considered consumables. Get an original crystal installed by a proffessional is the best route. Not much difference in price to buying one from them and installing  it yourself.
Anilv
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
