Poor amplitude
14 minutes ago, Nucejoe said:
If magnetized hairspring might be sticking so  you do get low amplitude and the watch runs fast.
There is a free app to download on your device called  WATCH ACCURACY METER, gives you the rate and beat error, not bad it will do until you decide to buy a tg. Using it you can see the rate which if crazy fast would indicate hairspring issue such as sticking.
Could be this rich. A short fast swing of the balance. Do the coils look close together ? That or the coils slightly sticking together if not completely clean
Yes, look close together.
Don't think they are sticking together, maybe magnetism.
I have one of the cheap blue ones about a tenner or so. It does work although im not quite sure how well. A couple of my dumont second hand tweezers keep getting magnetised all the time.
I made the mistake of buying Dumont carbon steel tweezers, unusable at moment.
What is the setting on the regulator arm . Fast or slow
Have they become magnetised?
I picked up 14 pair for 60 quid. About half of them are carbon steel. I have to demagetise every two hours or so. I think my computer on my desk  is a bit too close tbh . You only really need a no 3 and a no 5 and maybe a couple of really fine dressed ones for hairspring work. I quite like brass but they bend a bit too easy when the tips are fine. Cousins do some titanium ones that are quite cheap i might give them a go.
If you place a white dot on the balance wheel when its at rest,
Somewhere else the group we  we had a discussion on finding lift angle which is similar to this. I've found that using a certain type of highlighting pen with liquid ink worked much better than any other color because it would fluoresce under UV light. So you just dim the lights down and it glows really brightly and it makes it really easy to see the amplitude.
There's another way to do it but unfortunately it's astronomically expensive and no I don't know how expensive it is but I think of we would have to ask it's beyond our price range
I do wonder if we will for a clever whether we could do something similar? In any case they put a Mark on the balance arm the use a camera system to film it and then they can measure the actual physical amplitude and they can also determine the left ankle.
Thishttps://www.witschi.com/en/products/wisioscope-2/
The experience with This Group Has Been They Usually Don't Work the Best. And Then There Is the Other Minor Little Thing Whether You Have a Timing Machine or an App You Going to Have To Figure out How Many Beats per Hour This Is? Because the Age It May or May Not Be 18,000 Fortunately the Timing Machines Usually Have All the Standard Frequencies That It Probably Is and You'll Just Have To Figure out Which One It Is.
It's pretty easy for software to autodetect the rate, since the error would have to be quite bad to show up closer to another standard rate.
A difficulty is that a high beat watch will look better at half the proper rate.  E.g., measure a 36,000 bph movement as if it was 18,000 bph, and it looks better.  Only one direction is timed so no beat error.  But the difference between 36,000 and 18,000 is pretty obvious.
Elgin 173 with a cell phone.  I was trying to get an amplitude near 180° to measure lift angle.
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
    • Hands up all those who voted to leave the EU 😂, oopsie.  UK has just signed the Hague convention, next year that will provide cross border clout to British courts.
    • Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ?  Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
